I installed Gaffer SS braided brake lines last fall. Unfortunately I did not have much of a chance to ride the bike after the install due to the oncoming winter so had no real back to back comparison experience. I do notice there is less sponginess in the brake pull at the point of max lever pull however am not really sure how much difference it actually makes on the road. Part of the issue is I think I need to test back to back with another Versys with the stock lines. I also spent a lot of time bleeding the brakes to ensure there was absolutely no micro bubbles of air left in the system. Probably pumped 5x the reservoir capacity of brake fluid through the system to do this. What's your experience with braided lines?
One thing I have noticed though in my previous bike is replacing the stock pads with EBC HH pads did make a noticeable difference in front brake feel. They have less initial bite than the stock pads but provided a much more linear progression of stopping power wrt lever pressure. I had less fear of accidental wheel lock up when applying max brake force which I think might have translated into quicker stops.
