1 - 9 of 9 Posts
Not really a modification but, here's a cheap, easily made Jack to lift your rear wheel.
great idea, you can make it more compact by making the threaded part little less then half the needed length
Nice job !
Looks like it very easy to actuate
I would just put some sort of retainer on the frame slider so if Murphy was to show up, the stand would keep attached and you would run less of a chance to scratch that beautifull swingarm
LOP
Nice job !
LOP
a loop of paracord over the spool would probably be enough
I agree with Ed. Hobbit crutches are hard to come by. 0:)
As long as you don't require the "RING" along w/ the Hobbit-crutch, EASY-PEASY...!
:wink2:
Also - helps if you can "live w/out" Baggin's crutch....
1 - 9 of 9 Posts
