1 - 10 of 10 Posts
Well since the V needs a swingarm lift to do routine maintenace on the chain I decided to make up a chain oiler to do it for me. I sorta copied the Loobman design for a manual type oiler. I used a piece of music wire from some leftover RC airplane control rods inside the icemaker plastic line and bent to the needed shape. It seems to work pretty good.
What is that black plastic thing at the end? How does the oil get from the bottle to the 'applicator'? What oil is used?
I came from a belt drive bike and this 'chain thingy' is all new to me. Hope you don't mind all the questions.
Oiling the chain on this bike is a PITA. Without a center stand and without the ability to use a maintenance stand - rotating the chain is not easy. I rolled the bike back and forth in the garage today - I even dropped the bike once doing this.
Discussion Starter · #3 ·
>>>What is that black plastic thing at the end?<<<
That is a piece of cut ziptie stuck into the end of the 1/4" icemaker line. It deposits the oil on the sprocket where the chain meets the teeth.
>>>How does the oil get from the bottle to the 'applicator'?<<<
This is a manual oiler you just squeeze the amount out that you want and gravity does the rest. It slowly runs down as you ride and oils the chain.
>>>What oil is used? <<<
I used 80-90 gear oil but there is a large debate in the motorcycle community as to what is best and it depends on your riding conditions.
I came from belt drives myself hence the oiler. I hate chain maintenance. Do a web serach for chain oilers and chain maintenace and you'll find millions of dollars worth of peoples .02 cents. Oh and :welcome:
For chain lube.... the best product I've found is MFR Pro-Gold Chain Lube. I've been using this stuff for 8 years on dirtbikes. You won't find it on shelves but it can be ordered from any dealer that has access to Tucker Rocky. The carrier is mineral spirits so it doesn't fling once it dries (which is no time at all). I don't think it would work well in a lube system like this... but the product rocks!
I'm about a month away from getting a street bike... but you can be damned sure I'll be using Pro-Gold on the chain. It's proven itself in motocross and offroad racing so the street will be like a walk in the park.
Baddone, nicely done.
I had the Loobman but the parts that rubbed against the sprockets only lasted so long. Then I set it up just over the chain so it would do a slow drip because I added some foam inside the plastic line, but that got messy.
My latest solution that has worked for a long time is two foam paint brushes sandwiching the plastic line, so when I squeeze the bottle, the lubricant goes down the line and soaks the foam brushes, the foam brushes rub against the entire top of the chain. I give it a squeeze just before riding at times or during riding. My chain is always sparkling clean now since it constantly rubs against the WD-40 soaked foam and stays well lubed.
Do you have any pictures of your chain oiler?
Thanks
dbocz
I don't take good pics but it shows the idea. My chain always looks clean as shown and stays lubed. I only give a short squeeze to the bottle every few hundred miles. As mentioned, you can squeeze just before you ride or during. It is best squeeze it at lower speeds rather than hwy speeds.
I have an idea for a much better product that I just may market someday.
1 - 10 of 10 Posts
