The 2014 has a spot on the left, opposite the tps , a relay and mounting bracket need to be purchased for auxiliary power.I'm not familiar with the earlier models but on my 2020 I installed the aux relay and got power from the Kawasaki supplied connector in left front. That will supply power to your aux lights when key is ON.
I have Denali D2 with the HI/Low but not data dim. Mine are mounted up high just under front cowl.
Yes DM's according to your post DENALI 2.0 D2 TriOptic LED Light Kit with DataDim...Glen - can you tell me which DENALI lights these are (on my '15).
IMG_0665 copy by Ed Copeman, on Flickr
and turned ON.
IMG_0372 by Ed Copeman, on Flickr
Anyone running them on their V ? I’m considering adding them to my 2014 to increase my visibility but I’m also curious about how much they really help at night.
TIA
KC
I find that hard to believe, I have pressured washed these , with over 500 hours on them. I would love to see these damaged units of yours,(these forums contain helpful information, actual operating conditions and so much more, if a product is defective then it is equally important to post with photos, those D2 lights I bought were over $400 when I consider the SW Motech mount for them, it isn't a case of lacking the funds, but justifying the product is worth the money, you are the first complaint, no photos to prove** your post offers nothing to the reader of it, other than one would assume you are the expert on Denali LED lights) along with photos showing Denali, although the knock offs are getting good.these lights are really bright, but there is a serious design flaw. i had the 'pleasure' of having 3 of them getting broke. either they leak water from the back, or how they attach is very poor and I had to goop these attachment points with limited success. so my advice is: don't buy that crap.
I took apart my aux lights and when I reassembled them I didnt use their gasket properly on one and it leaked till I figured it out. Its like taking apart a water resistant watch to change the battery, pay attention to the gasket!I have no idea how water could get in
Run them day and night. Never even use the on/off switch! Use every day for commute. 40,000m. On my 5th year. No problemsAnyone running them on their V ? I’m considering adding them to my 2014 to increase my visibility but I’m also curious about how much they really help at night.
TIA
KC
How did you run the power for them ?Run them day and night. Never even use the on/off switch! Use every day for commute. 40,000m. On my 5th year. No problems
Indirectly. You should install them by the switchgear.How did you run the power for them ?
