Background: Last September I installed new JT sprockets (stock size, rubber front) and a new DID 520 ZVMX chain. This chain is rated for 1000cc and up bikes, it is excessively strong for a 650! Chain slack was set on the loose side as I’ve found the factory spec is too tight to prevent binding. Chain alignment was set with an alignment tool, not the factory markings that are off. I have an automatic chain oiler installed and had been using 75w90 synthetic gear oil until this spring when I switched to heavy weight chain saw bar oil - it sticks to the moving chain better! I have about 11,000 km of all weather riding on these parts.
While preparing for a tire change, I was wiping down the chain and noticed that an X-ring was sticking out:
I said some bad words, then inspected closer. I’ve found that the inner link appears to be bent:
I (obviously) marked the damaged link with red paint so I can keep an eye on it until some new master links are delivered and I can replace the damaged links with ones left over from shortening the chain.
Has anyone seen this before? Any idea what might have caused it? I paid a premium for this chain in the hope it would last more than a year, so I’m rather disappointed to find this.
Thanks!
Thanks!
