1 - 20 of 144 Posts
· Premium Member
It'll get better after break-in then even better when you switch to synthetic oil...
· Super Moderator
· Registered
I kinda wondered the same. Got about 200 miles on my new V and she shifts pretty hard, especially that first clunk down into 1st. If I don't keep my hand on the front brake I'm afraid she's going to lurch forward. I thought it was just mine, glad I'm not alone.
· Registered
As far as I've seen on these forums, all the Vs have that clunk into first. I've been running Amsoil AMO 10W-40 and Mobil 1 4T oils with good results. Most shifts are much smoother now than they were with the factory fill. Nothing I've seen suggests that the longevity of the transmission will be affected by the shifting.
· Registered
this bike has positive neutral finder which is the major cause of the clunk. For those who don't know what that is, when you shift down to first with the bike stopped and then lift the shift lever, it will not go into second unless the bike is moving. This makes it real easy to find neutral and Kawasaki pushes this marketing feature.
· Registered
Discussion Starter · #11 ·
I will have to try that, I have tried moving the shift lever up and down to change the pressure on my boot. Havn't found a decent combination yet. Sometimes it is though it doesn't clunck into 3rd until the shifter is fully released. Like it has to use the full range of up and down movement to engage. Shift lever clicks up, release, still in 2nd gear. It does seem to shift better at higher RPM's though. I will probably talk to my dealer about it, have had 50 or so bikes and this one shifts worse than anything I have ever owned. I really love the bike other than that.
· Registered
Hey, I didn't know Amsoil's AMO 10W-40 had the JASO MA spec. It retails for less than MCL 10W-40, and even a bit less than my AFF 0W-40. :thumb:
http://www.woodsbrosracing.com/amsoil/amo.htm
· Registered
You may have to remove the footpeg from its mount to access the shifter's main pivot, to clean and grease it. There are seals there, but it likely wasn't properly packed with grease... Use NLGI #2 grease. You can also spray some chain lube on the shifter rod ends, under their rubber boots.
· Registered
Yeah...she's clunky. I find that pre-loading the shift lever and then barely pulling the clutch, she shifts in effortlessly..........
+1. This bike is new to me - and the clunky seemed extreme to me. But the fine folks on here assured me it was normal - and as long as I pre-load 2nd gear - no more clunk. 2nd is the only one that does it for me - so maybe the mileage already on the bike has taken care of 3-6???
Good luck.
· Registered
Have to say that my Versys 'box is probably the worst gearbox in any of the 20+ bikes I've ever owned and is the worst feature on an otherwise excellent bike. If I decide to change my bike next year, top of my list is the DCT Honda Crosstourer. Now that's a brilliant set-up. :thumb:
1 - 20 of 144 Posts
