1 - 2 of 2 Posts
2020 V-x300 with 2000 miles. When pulling in the clutch lever, regardless if the engine is running or not everything feels like butter the way that it should. But, more often that not when riding and it makes no difference either up or down shifting the clutch pull and/or release feels like there is a couple of cable strands broken when shifting and hanging up in the housing. If I immediatly after shifting just actuate the clutch lever a few time it feels very smooth. Is this the normal feel from the transmission?
I have a 2020 V300 with 2500 miles and I don't have this issue. You may be correct that something is causing friction in your cable. Sorry I can't suggest a fix.
1 - 2 of 2 Posts
