1 - 16 of 16 Posts
I know ram makes some pretty good mounts, but I am looking for the kind that specifically attaches to the gas cap. I think its a very good position for a camera looking through the windshield.
Top priority is solid mounting (plastic is ok if its high quality).
Other nice things would be the ability to fill up my tank while it is on.
So far all I can find are generic ebay and amazon mounts for like 25 bucks.
This was taken with the camera mounted on the side of the gas tank with a ram suction mount. But the only problem is with long legs it was in the way of my knee.
Norrick
Have tried a gas tank mount and :
1. As you have to have a long mounting arm to get the camera high enough to see over all the front clocks etc , it induces massive camera shake. You realy need a tripod mount onto the gas tank.:thumbdown:
2. No where to mount the tank bag:thumbdown:
3. you always see things through a fuzzy screen:thumbdown:
In all not worth the effort :( then again you may have better luck than me.
Weljo
Try mounting it on top of one of your hardcases as this guy has done.
Its a great viewpoint and your knee will not suffer :thumb:
No Video
Richard :D
PS excellent music as well
Weljo
No Video
Richard :D
Thanks Richard, Its a local (D/FW) band named Flickerstick.
That mounting spot was when i was trying different places to mount to.Also tried handlebars,crash bars and a few other places.but the best place for video was mounted to one of the forks and i have a camera for photos mounted to the windshield bracket.
You can see both camera here...
IMG_1431 by weljo2001, on Flickr
IMG_1432 by weljo2001, on Flickr
Videos.... http://www.youtube.com/user/weljo2001?feature=mhee
Latest Photos With Drift Camera... http://www.flickr.com/photos/[email protected]/sets/72157630038430120/
Here is a shot from the bottom of my SW Motech bars. Had some vibration but turned out ok.
Norrick
I like gas filler mount for a camera on some bikes, but not for the Versys.
Camera needs to sit too high, like you said. I have a great gas-filler mount for Kawasakis, but it would need to be modified to use with the Versys. And with the required riser, it would be in the way and I think dangerous too if you had an accident.
On the bike I used it on I left the mount on all the time and had no problem using tank bags. Of course it wasn't compatible with gas-filler mount tank bags. Which seem like the best kind to use on the Versys...
On the Versys I like to shoot from low and behind the front wheel to the side, mounted below an engine guard.
My windshield is clear and non-distorting so I wouldn't mind putting a camera behind it to see the speedo and tach. I plan on using a wide angle lens so you see in front of you on both sides of the windshield, not just through the windshield.
Ideally I'd like a nice camera on the tank facing forward, and maybe another camera (as small as possible, doesn't have to be high-def) on the back facing rearward. Make some picture in picture videos so you have like a virtual rear view mirror.
I've only ever fallen once, and it was on a ZX-6R, which puts you leaning much farther forward than on the Versys, and even on that fall, I lowsided it and seperated from the bike while I was on my side; I didn't go near the tank. Kinda funny it reminds me of when the shuttle releases its two solid rocket boosters. I can't see a tank mount being a hazard any more than the windshield unless you literally collide head on with something, in which case the camera on the tank is the least of your worries.
Tiwsted Throttle sells one that mounts to a tank ring. Its pretty spendy. Even the clearest windscreen will not be optically correct. I'd post a link but I can't seem to get TT's site to load this morning.
There site is working this is what I'm talking about
Link
$95 is a bit much for me plus you need to add the tank ring for another $40....:eek:
I've never tried a gas tank mount but I've used just a standard RAM mount on the handle bar and it gives a similar POV.
Also, there is a chest harness for GoPro's that gives a good view (but my tankbag tends to get in the way with that).
Is that the Drift HD or Drift 170 Stealth you are using.
People have commeted on other forums, that the new Drift HD hardware / software has been set-up for Snow scenes more (ie a Bluish tinge), rather than what we require (warm and colourful) :confused:
:feedback:
Richard :D
:feedback:
Richard :D
Both of mine are the Drift HD170 Stealth. They came out with a newer one the Drift HD its smaller and has a 9 mp camera instead of 5. I like mine because you can run a power cable while filming so no need to worry about batteries. I had one earlier that got damaged in a wreck I paid 239.00 for it but over the winter Amazon had them on sale for $159.00 so i bought 2. Now thier back over $200.00. Not sure about thier software i just use the iMovie program that came on my MacBook Pro.
You can use the ram mount that replaces the factory clutch arm mount bolts and a ram 12" arm and you will have a rock solid mount way out front with nothing but clean air view. I have been using it for months with my go pro hero 2 it's been perfect.
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045051048057045055/Default.aspx
http://www.expressmounts.com/ram-mount-long-arm-b-socket-ram-b-201u-c.html
http://www.expressmounts.com/search/q=go+pro+tripod
These 3 combined give me nothing but clean view rock solid and no vibes.
1 - 16 of 16 Posts
