1 - 15 of 15 Posts
Hello folks from India. I'm running a Ninja 650 (2012) but with the Versys fork setup
Normally it looks like a Ninja but slightly taller
But for off-road expeditions there's an off-road kit which makes things minimal and robust.
The Versys wasn't sold until late 2015, and I didn't see the point of selling the ninja and getting the versys. I imported the Versys forks, clamps, riser, rear shock(2010 model) from US. The stock N650 suspension is simply inadequate for anything other than good tarmac.
I ended up here after reading lots of useful info about the 650 platform. Right now I'm going through the burnt stator syndrome :D so will be posting around looking for a updraded fix over the stock setup.
I ended up here after reading lots of useful info about the 650 platform. Right now I'm going through the burnt stator syndrome so will be posting around looking for a updraded fix over the stock setup.
Simple fix is in the How To Forum, install a series regulator and any stator will work.
:welcome:
Thank you for the welcome onewizard & weljo2001!
I've been reading precisely your inputs on the matter.
I'm looking to rewind the coil as a new stator + regulator here is an obscene $700 equivalent. So it seems that the Polaris regulator and coil rewind seems to be best + repair upgrade. The rectifier seems to be alright as per the workshop manual test of hooking up with three batteries and a load. I guess it's just the aging and super hot climate over here.. but I'll still go in for the regulator upgrade rather than staying with the stock unit as it seems to be culprit in blowing up the stator
Why doesn't Kawasaki use the series regulator from the factory? Cost cutting much ?
Fortunately I have a onboard voltmeter so I stopped using the bike the moment the voltage readings were off from usual. The coil still charges as of now but only above 3k rpm. I have a CBR250 as a standby so will take all precautions to fix the Ninja
Welcome!
I'm in the process of working on something simular, but is currently on pause do to two, new to me bikes within a couple weeks. After I finish up the bike I am working on, do to less work to finish, I will be getting back to it very soon!
The good thing about using the Ninja, you have more power all around and it is more forgiving than a versys, they are tuned differently. The Ninja is a superb platform, have fun with it!
Welcome!
The 650 motor is kind of ideal for touring in India, the bike is happy with the fuel we get here and fast enough to stay ahead of all. Only thing was the rather low ground clearance on the stock setup, which was solved by the Versys swap. I'm going to keep this motorcycle till it's run into the ground. (While adding other motorcycles in the future)
The 650 is the perfect size! Low cost out the door and insurance wise. Plenty of power for one or up to, two touring. I never had any ground clearence issues with a Ninja 650 lowered, unless you are going over curbs or the like, let alone stock height or taller. It also has a high mpg for what it is. It will last a very long time as long as you take care of it!
I can say I have helped members on this forum all over the world, at least 4 through PM. My first advice would be to buy a used Polaris regulator, when you are ready I can point out good buys. Buy a Triumph harness as posted in the How To Thread.http://www.kawasakiversys.com/forums/74-how-forum/105962-stater-output-stator-testing-device-load-ratings-2015-a.html
I have a thread that explains why a China Star stator will last as long or longer provided you follow my advice;http://www.kawasakiversys.com/forums/74-how-forum/124601-stator-oem-vs-ricks-stator.html
One person on this forum rewound the stator by hand, http://www.kawasakiversys.com/forums/74-how-forum/87106-stator-rewinding.html I don't recommend it, you can buy a new China stator that will last longer than the OEM, provided you convert to the Polaris / series regulator. I have a explanation for that in http://www.kawasakiversys.com/forums/74-how-forum/125594-regulator-series-shunt-star-delta-explained-technical-info-2017-a.html
As to continued use I thought this thread might help http://www.kawasakiversys.com/forums/74-how-forum/116313-stator-how-long-far-can-you-ride-battery-without-stator.html
Revision to triggering headlight relay 2017
http://www.kawasakiversys.com/forums/74-how-forum/124881-polaris-regulator-install-2017-revised-parasitic-drain-brake-trigger.html?highlight=brake+trigger
Triumph Harness http://www.kawasakiversys.com/forums/1348442-post16.html
:welcome: aboard!
Ye$ - co$t....
Thanks for the welcome!
I can say I have helped members on this forum all over the world, at least 4 through PM. My first advice would be to buy a used Polaris regulator, when you are ready I can point out good buys. Buy a Triumph harness as posted in the How To Thread[/url]
Thank you! The stator problem is one of the most infuriating kind I've encountered on a generally troubledfree 650 platform.
Yes I'll probably order a China Y pattern stator instead of the OEM delta, meanwhile I'll also rewind the stock burnt stator by myself to keep as a spare. I absolutely hate the downtime caused by this as winter is the peak season to ride here.
So yes I'm ready to order the Polaris used series regulator + stator. I still haven't found the triumph wiring harnesses post yet amongst the links in your reply.
Thanks a lot again! If continuing in this thread is inappropriate we can continue the discussion in the appropriate thread.
Triumph Harness / Headlight Trigger
I added the additional links, even I had trouble finding them, so I have copied this post into a sticky related to burnt stator http://www.kawasakiversys.com/forums/74-how-forum/132250-12-2016-stator-failure-posts-posts-related-those-converted-series-regulator.html?highlight=brake+trigger
These links are also in the above thread.
As to discussion, this is your thread,( restrictions on new members to starting posts in other forums, makes this thread the right way to go) if more information gets added and I feel it contributes to the issue, I will copy those posts into a appropriate thread, and you will be made aware of it.
The Versys is great, but I have to say the off-road Ninja looks pretty cool!
Hey thanks ! :D (insert *adapt improvise overcome* bear grylls meme)
Welcome on board Mr S. Been following your exploits on the KNOG Facebook group. I was the only active Indian out here with my share of questions, good to have you around as well :D
Hmmm I havent yet figured out who exactly you are on KNOG. Someone with a versys with plenty of kms
ri
Getting a new stator is problem as of now as due to the weight itself the stator shipping cost is more than the stator cost. Bummer. Ill have to rewind the coil I guess to make the repair cost effective. Since I will rewind the coil should I stick to the OEM delta pattern winding or go for the star winding pattern ? Also so far I only have found two original oem rectifiers for sale.
Polaris OEM RR (https://www.ebay.com/itm/RZR-800-S-Ignition-Voltage-Regulator-from-2013-Polaris-42/232579542095?epid=1411820056&hash=item3626d22c4f:g:Z2QAAOSwJtdaHuHh&vxp=mtr)
Polaris OEM RR #2 (https://www.ebay.com/itm/2013-Polaris-RZR-570-Voltage-Regulator-Rectifier/292366756332?hash=item44126aa9ec:g:8vEAAOSwk-1aIYva&vxp=mtr)
Triumph harness (https://www.shoptriumphparts.com/products/Triumph/Link-Lead--Regulator/9969673/T2500676.html)
I did a revision http://www.kawasakiversys.com/forums/938897-post3.html . What I would advise is to wind it Y connected , but do a almost proper conversion ( use 16 gauge magnet wire)as I changed in that new post. The advantage is , it is very easy to lose count of turns when winding by hand, if you are off in turns between phases , Delta connected you will get circulating currents, the number of turns is greater in Delta so therefore the amount of total insulation of the magnet wire is greater than Y. A mistake in Y on turns per poll will make very little difference other than the individual phase output current may no be identical , but will have very little affect on the output. Voltage per turn is reduced because the line voltage output is 1.732 times the phase output voltage , however phase current and line current are identical connected Y, thus the reason to use 16 gauge magnet wire.
1 - 15 of 15 Posts
