1 - 11 of 11 Posts
Hi all, I was in Walmart buying a tyre repair kit and came across a shelf full of additives that were for petrol that has ethanol in it... I have googled it but I am unsure if this is something I need to be aware of with my 650 LT?
Should I use an additive in the fuel? Never heard of it in the UK.
Regards
John
ps I shall be leaving the bike in storage for extended periods when I return to the uk if that has any relevance?
Administrator
Storing Longer Than 3 weeks
recommend adding fuel stabilizer to a full tank of fuel, should be run in for about 5 miles to get it into the injectors. Most like Stabil or Sea Foam , good for about 1 year.
Ethanol in gasoline quickly leads to phase separation and water absorption from moisture in the air. It causes corrosion and turns to white crap if left in tank for more than a couple weeks. It also stinks of rotten corn dogs when it burns.
UK already has about 5% ethanol in most of their petrol... The situation varies depending which state you're in.
Ethanol-free gas stations in the U.S. and Canada
Classic Car Owners Given Reprieve From Ethanol Increases At Pumps | CCFS UK
Ethanol And Other Additives In Fuel - General Trials Talk - Trials Central
Never had any symptom or problem with e10 gas when visiting US.
But in fall I rarely visit US, and most gas here is without ethanol, but I always use stabil for the winterization anyway. So you don't need to put stabil all the time, just when you won't burn that gas soon.
just put a full tank of E-free fuel in befor storing it and fill it as full as you can then add a shotglass full of seafoam. also plug it into a battery tender, then when you come back next year all you have to do is change the oil, check your tires and ride
Most of the horror stories about ethanol in gasoline are pretty much just stories. E-10 is the max I would use (not E-15 + as ethanol tends to deteriorate some rubber/plastics).
With regard to storage for an extended period; does anybody worry about the tires sitting on one spot, especially on concrete. I always heard you should at least put your tires up on a piece of wood for extended storage.
Unfortunately I have first hand experience with this.
Several years ago I bought a 7 year old Honda ST1300 with just 7500 miles on it. When I asked about the low mileage, the owner told me the previous owner had let it sit up for a "while". I test rode it and all was OK so I figured no harm had been done by it sitting unused. Even on the 600 mile ride home and the subsequent 2 or 3 weeks it ran like a champ.
After about 3 weeks from puchase, it started acting like the fuel pump was going bad (started missing badly on acceleration). The ST1300 has an upper and lower tank with the lower tank containing the fuel pump. When I opened up the lower tank, here is what I found. A classic case of Ethanol phase separation, verified by someone I know who is a mechanic. He told me it was rare to get a rusted tank in his shop until Ethanol began appearing in gas. After that, he said he saw several per week, with more showing up after things sat up all winter:
Here is a diagram showing the phase separation process (discussion of the process HERE ):
It was not an easy fix. Even with doing it myself, it cost about $750 for parts (new tank, fuel pump & associated bits). It was a long job because the lower tank removal was pretty involved and tedious:
Since going through this, I always leave the bike parked with an absolutely full tank to prevent moisture laden air from coming in contact with the gasoline surface. If it's going to be parked for any length of time I'll put in STABIL and start the bike up every few weeks to remove any water that has settled to the bottom of the tank where the fuel pump pickup is.
This is very hard to find in areas in and anywhere near metropolitan areas due to environmental regulation.
That's where front & rear stands come in for me
The bike takes up less space parked vertical as well
I store my Vs on BOTH a front and a rear stand so my tires are OFF the hot floor.
1 - 11 of 11 Posts
