1 - 20 of 20 Posts
It that a throttle lock, or an actual cruise control?
I have used throttle locks when I lived in Florida. They work well on roads with no elevation changes. Where I live now they wouldn't work well at all. Have to constantly move the throttle to maintain speed.
I seem to remember it being a throttle lock that gets released by using the brake lever. Seems like a good idea. I just checked and they do have a Versys model.
I've used a few types of throttle locks. On one bike I could slide my grip slightly to the left and it would "lock" (wouldn't return on its own). That was the simplest. I've had a Manic Salamander bar end unit that I never really liked--though their bar end weights are awesome. And I've got a Go Cruise which is the simplest and best I've seen lately.
On trips it's great if you need to do something with your throttle hand. But I almost never use it.
+1 on the Go Cruise. Simple and works.
I have the Go Cruise as well. I also never use it, but it's there if I need it. The times I have used it, it works for a short amount of time before the bike starts to slow down. That isn't really a complaint because the times I've used it, I've only needed it for a short amount of time.
I've got one on my Versys. I'll post pics in a little bit. Its a generic clamp/friction type that I keep adjusted so that it just barely holds the throttle in position. I keep my hand on the throttle while I use it but it relieves the need to keep constant tension on my wrist. Its not precise and doesn't work as well as a throttlemeister(http://throttlemeister.com/) but it's a lot cheaper and does the same job.
At the risk of overstating the obvious
No matter how plain or fancy, a throttle lock is just that & only good for a short break on flat ground. They are not a replacement for an actual cruise control unit. With the go cruise; if you do something non-sensical like reaching across with your LEFT hand to set the speed it's possible to hit the kill switch. If you do that at 70 mph it can be very disconcerting until you figure out what happened. If you just reset the kill switch without releasing the lock it gets even more exciting.
My appologies, yes it is a throttle lock but has the ability when pressing on the brake lever to release the throttle lock. The biggest issue is that it's expensive at about $199 USD.
I saw the Go Cruise advertised and on You Tube. At $10 versys (pardon the pun) $199, I'll give it a try.
If the Go Cruise slips, wrapping a rubber band around it will fix that. I used it over grip puppies for awhile, and when I removed them it would slip on regular sized grips until I added a rubber band.
They now include the rubber band in the packaging of new ones too. :)
I have a Break Away on my 1700 Vulcan and it works great. Yes. expensive but I like it for that bike. On the Versys, I use a basic grip lock that just holds the throttle so I can rest a bit on long trips. Very cheap but works fine on the Versys.
I mounted mine to the top bolt of the clamp/ mirror mount of my '09 master-cylinder, with a short piece of aluminum "pipe" for a spacer.
I have the Go Cruise as well. The times I have used it, it works for a short amount of time before the bike starts to slow down.
Remove it every now and then and clean the part that grips your throttle... And the part of the throttle that gets gripped... it renews the overall grip. I just use whatever is available... 409 or Simple Green, etc..
Also... If you set it a little above where you want it to be... a cleaned up pairing will put you in the ballpark and keep you there. I had great luck on my cross country last summer.
Owned several both styles
I have the Brake-away on my 09 versys. Love it. Like the brake lever release as well as the "push button". I have the throttlemeister on my FZ1, it does what it needs to do, after 30,000 miles had to change the shim/grip assembly. It was starting to creep slow when engaged. Works fine now, just keep the shims from the kit they send you. Back to the Brake-away this in my opinion is the best next to an actual electronic cruise. If giving the chance I will install on the FZ1 just for the ease of release/engagement. As far as using with heated grips/ not sure, but where there is will there is a way. I'll cross that bridge when I get to it.:thanx:
1 - 20 of 20 Posts
