No power at all no dash, no horn, nothing. You cant even hear the usual whirring when you turn it on. I've checked the fuses, the main fuse relay, and changed the battery. Cant figure this one out. Help?
there is a post some where in this forum on how to remove and clean the contacts in the key switch
Maine Fuse?
Check the left side near the battery. There is a little plastic looking cover box that has a 30 AMP main in it. :cheers:
This happened to me when I short out the circuit trying to install a spot light. There is a spare 30amp fuse next to the one in use.
