1 - 10 of 10 Posts
I am back on my radial calliper project and need a pair of fork tubes c/w the bottom leg casting in order to make a 3D model
The goal is to machine a new bottom leg casting to hold a radial calliper rather than use a scabbed on bracket.
Anyone have a pair of bent fork tubes?
I researched this quite a bit for my bike and "looks" like you can use the lowers from a recent Kawasaki concours and you install that on your tubes. fender mounting points would need to be fabbed.
So you need - Concours lowers, axle, spacers, rotors and calipers.
I have already bought the rotors and calipers for my bike. I am going to buy some lowers soon and try it.
My bike is the versys 1k btw but I think the mod may work the same on the 650.
The versys and concours wheel is a direct fit (I tried)
On my bike I already switched to a concours front wheel because it is stronger than the versys wheel.
I have PM'ed Jfman but for those not in the loop, it appears that the USD concourse forks have a 43mm fork tube as does his 1000 Versys. - the 650 Versys is 41mm
Having said that, the Concours is not available here in Thailand so my info is coming via Google
There must be a different fork leg that I can use rather than have to machine a new one. Or a complete new fork with radial calliper mounts
Ok my bad, I assumed versys 650 was similar to Versys 1000. My research was done for the 1000.
I would look into Kawasaki models with 41mm and radial brakes and see what is compatibe... But I cant steer you further.
My big problem is that not all bikes are available in Thailand and the local knowledge to mix and match is limited. I can only find out so much on the internet and really need some help on this
My problem at this point is the longer Versys fork. Does anyone know of a 765mm long fork (cap to axle centre line) with dual radial brakes that can fit on the Versys. Alternatively an inner fork tube that I can fit into the existing forks. Last choice would be a suitable bottom casting, but it will be tricky to press the new one on - off is easy with a hollow jack
I could make one but it is a lot of work, and I need a Versys one to model as I would rather not tear mine down to find that I cocked it up or cannot do it.
I imagine that one could use shorter forks off a sport bike and a lowering kit, but I do not want to give up the longer travel suspension with our compromised roads
Have you checked with local salvage yards? There has to be some bent Versai in the area! The fork has no salvage value if bent, I'd think they would be happy to get rid of them.
That was my first try, but I am in Thailand and nothing is thrown away - bent forks are straightned and the insurance company will fix half assed every time.
In any case I have given up making a lower leg casting and am now fitting BP-SFF ZX6R forks with 310mm ABS radial brakes.
Yes they are shorter, but with a speedy lowering block at the rear it will work
Which leads me to the next problem. Is the 2013 ZX6R 310mm rotor the same as the 2013-14 Z1000
the Z1000 is made here and I can buy new rotors for the price of used ones in the USA
Yikes!
Sounds like you guys need more lawyers! :)
Well, the new fork setup seems like a more fruitful route anyway. But it could be moving away from the core of Versys Lore. Maybe an ER6 Performance shop would have some answers. BRP?
1 - 10 of 10 Posts
