1 - 20 of 57 Posts
2009 Versys
Picked this up from an old friend. It has sat 4 years basically untouched. My friend wanted to get it going, but couldn't get the gas cap to open. This is a known issue, and can be very difficult to open as the tabs corrode.
Anyhow, a deal was struck and I went over and got it. The bike is basically a barn find, with cobwebs on it, and 10 year old tires.
Loaded up and brought it home.
Washed off the dust and spider webs.
Took all of 5 minutes to get the cap off. I used a small angled pry bar and worked it into the cap and it popped off. You can see that the tabs are corroded and are well frozen.
I popped in a battery and it lit up and turned over freely. The tank is empty, and rusty, and the fuel pump is not hooked up. But all in all it looks like a decent project.
Overall it looks great.
I live 10 minutes from the ocean, some serious corrosion here in the air. In the winter Ill give the whole key-lock mechanism a spritz of WD40 as my bike sits. For the other 9 months...As Fastoman once stated, fill your gas up high enough to immerse the gas cap lock in the gas. It keeps it clean and moving real smooth, great fix!
2009 Versys
Discussion Starter · #5 ·
Some more details.
Mileage is low:
SW-Motech goodies:
SS Brake lines:
Are these factory grip heaters?
Seat Concepts seat, I have the original and foam:
Datel meter:
Aftermarket levers and home made guards:
Aftermarket foot pegs:
Is this a factory sidestand?
I also have the factory screen and a tinted touring screen.
2009 Versys
Discussion Starter · #7 ·
Yeah, I read about it on here. I hope I can now free it up and make it work properly. Seems that some have done it.
2009 Versys
Discussion Starter · #8 ·
Some more details.
Mileage is low:
SW-Motech goodies:
SS Brake lines:
Datel meter:
That bash plate or rock guard is an Algard. Was made in Slovenia for awhile then a forum member here made about 10 clones. Very desirable and hard to find. I had one and really liked it. You can get Keyless Gas Caps off eBay cheap. I've used one on my last 3 bikes... kawasaki versys 650 keyless gas caps: Search Result | eBay
The side stand has been cut down and has a MotoWerk Flatfoot on it. Has the bike been lowered ????
Those are aftermarket heated grips.
2009 Versys
Discussion Starter · #14 ·
Got the cap apart and found it is broken beyond repair, no surprise. I probably broke off the nub why I pried it out. Tons of corrosion.
This is the tool I used to get it our, quite easy actually.
Here is the new one I just ordered for $30. Hope it fits and I can swap out the key tumblers. The dimensions are good.
My key tumbler:
2009 Versys
Discussion Starter · #15 ·
For the luggage racks, I have a pair of new Givi top case mount plates laying around. I think I will bolt them to the racks, and use these for panniers, maybe even paint an accent portion on them in matching green.
Here are the racks I will bolt or weld on.
2009 Versys
Discussion Starter · #19 ·
Got a decent shot of the tank rust. Going to tackle that after I get back from vacation.
I have a set of late model BMW R1200GS grip guards. They don't guard much but the wind, but I think they will be useful and look good. I need to trim down the bar end weight, and then fabricate a mount for the other end, but I like them.
1 - 20 of 57 Posts
