1 - 20 of 20 Posts
I'm about a month into my Versys 650 ownership, and am finding the stock headlight pretty inadequate - I feel like I'm going too fast for it to be useful above 60 kph on anything other than well lit roads. So I'm looking at auxiliary lighting options along these lines:
https://www.cyclopsadventuresports.com/-Long-Range-Optimus-LED-Auxiliary-light-Round_p_10.html
My question for people who have been down this road is, how are you mounting lights like this, on bikes that don't have crash bars that cover the fairing, like the Touratech ones? I'm planning on investing in the SW Motech ones, which from pics I've seen, probably won't be suitable for hanging lights off of.
I'm looking forward to seeing solutions that you have found for this problem.
[edit] This is for a 2017 Versys, so from 2015 on.
Another thing you can easily do is upgrade the OEM bulbs to Philips Xtreme Vision bulbs. Still only draws 55W but produces much whiter light. I'm using them on my Versys, and used them on prior bikes, too. They're the next best thing to HID.
Reactions: rsherman
...My question for people who have been down this road is, how are you mounting lights like this, on bikes that don't have crash bars that cover the fairing, like the Touratech ones? I'm planning on investing in the SW Motech ones, which from pics I've seen, probably won't be suitable for hanging lights off of....
Here are the DENALI DM lights on my '15 V650LT, on a bracket I made to "hang them off my SW-Motech crash bars".
I just 'bent-up' a piece of steel, then welded it to the lower spacer, aligned it as necessary, followed by torquing that mounting bolt. Works PDG!
[I use them mainly as look at me, SEE ME, cage drivers!...]
2013 v650
I do not have crash bars installed so I used the lower attach bolt for the radiator fairing. I used a longer bolt and spacer to attach the light U bracket. They are just inexpensive 10 watt work lights off Amazon. They are more for see me lights than for lighting up the highway. I found this mounting on a very old post here. I am using it on a 2013 v650.
Yeah, that's a great idea, and something I'm going to do regardless of whether or not I add aux lights.
That's really cool - unfortunately, I have no ability to fabricate where I live, and no welding skills whatsoever. But good to know that lights can be hung off the SW Motech bars.
That looks like a great solution!
Here are my lights, mounted on my Hepco and Becker Crash bars. These have been on for 10 months now, and have not budged a single inch...
[/QUOTE]
'Brackets are Simpson concrete form angles and a couple of u-bolts, spray painted black. Not the most elegant, but the they get the job done and there has been zero need to re-aim the lights since I installed them.
I can answer your question on the cyclops lights, i have the 10 degree version on undermirror mounts on my concours 14,plainly put they are awesome, 10w draw per light so no overloading the electrical system and leaving headroom for my heated jacket and gloves. get the skene dimmer and once you figure out how to wire it all up you can dim the optimias to between 10 and 100 percent with the stock dimmer switch. mine are set at 20lo/100hi. on hi beam at 100% they throw a beam far enough to drive comfortably at 80mph with room to spare.clyclops advertises 990 feet. add some good led bulbs in the main headlights and that extends a bit.
im picking up a versys on 10/6 that comes with advmonster lights already mounted, if they dont match the optimias(not likely) ill order another set. they are pricey but worth every penny if you ride at night.
the advmonsters will move to my klr and the rigid lights on there will swap to my atv. i am a firm believer in modern led lighting.
I am an old long distance rider from the piaa 910/520 era where you needed 200w+ to run good effective lighting, the modern LED driving light is a wonder to old guys like me.
If you have the T-Rex Racing engine guards or any 0.75"/1"/1.25" diameter engine guards/ light bar, you can do something like in the video. FYI - not my video.
YouTube video link: https://www.youtube.com/watch?v=MJNbNazp6yc
AMAZON -Rigid Industries 50481 D-Series SAE Fog Light Set - street legal SAE fog lights
AMAZON - LAMPHUS 2PC Off-Road LED Light Bar 0.75"/1"/1.25" Horizontal Bar Clamp Mounting Kit
IMHO Rigid Industries fabricates great lights (life time guarantee, etc.).
Note: I have 4 on my Versys (2 spots and 2 floods). I usually run the floods during day time for conspicuity. If I ever need to ride at night time, the spots would be ON.
1 - 20 of 20 Posts
