1 - 18 of 18 Posts
I was thinking about trying the front rubber dampened sprocket out, but not if it is AL. The OEM rear sprocket is about $20 cheaper than a Sunstar steel rear sprocket so it may be AL - ?? The front rubber cushioned is only $10 more, but it may be AL ??
My Sunstar steel sprockets still look good, but the rubber dampened front sprocket seemed interesting for sure. Why don't they have critical information like this on the oem parts database??
THANKS!!
O.E.M. sprockets are steel and probably made by Sunstar. I've used both rubber dampened O.E.M sprockets and regular Sunstar sprockets and really can't tell any difference.
Thanks Walter! It's what I assumed from the expert postings here: enough to pull the trigger.
I'm looking forward to getting my parts. But getting all the specials including shipping, they won't all be here for at least a couple of weeks. I've got another oil change (in miles) in my chain now (I hope.)
Any one have a part number for a oem 14 tooth rubber dampened front sprocket
13144 is 15 tooth. There are no other oem transmission output sprocket sizes from Partzilla's Kawasaki database (for 2012 anyway). All the oem databases are the same (but Parzilla's is usually cheaper because they are the biggest parts house there is.) Their online oem databases are visually cleaner than others too.
Kawasaki Motorcycle Parts 2012 KLE650CCF Versys TRANSMISSION Diagram
Part number for zx6
16 tooth works on versys
kawasaki part no. 13144-0038
versys 15 tooth part number
kawasaki part no. 13144-0024
Looking for a 14 tooth in a Kawasaki part number that will Work on a versys
THANKS!!
I'd skip the aluminum sprockets. We riders are an emotional bunch when it comes to keeping up with our bikes. We change the oil way more frequently than we need as with other maintenance to keep things as new as possible...as if we can give them life eternal.
Fact is, I've never noticed enough wear on a steel sprocket that it's actually been worth changing. I have and likely will continue to as I also suffer this emotional affliction. Aluminum OTOH, is not up to the job. The aluminum sprockets I've used broke teeth long before their new chain was ready to replace.
Unless you're racing and need to shave every ounce to cut your lap time, I'd leave the aluminum sprockets to those who do. Steel ones are a FAR better choice for the real world.
At about 18,000 miles I knew that my chain/sprockets were through. In the end, the OEM front sprocket was the problem. I think that I caused the most wear when I had my chain a bit too tight for some time. I am sure that you can wear steel sprockets. Then again, since half of this forum owns a Versys for about 6 months, this may never really bother them.
Reactions: saddlebag
When ever I have needed to change a chain, the front sprocket has been toast as well. The rear seems to last slightly longer, maybe every second chain replacement.
I highly recommend in investing in a chain breaker and rivet tool like this one. One chain change and it has more than paid for itself and you'll always have the tool. Lots of YouTube videos on how to use it. It's very easy and quick to use.
STOCKTON TOOL COMPANY - Chain Breaker and Rivet Tool Kit - Multi-Tools - Tools - Accessories - Cycle Gear
THANKS!!
Both front and rear OEM sprockets are steel. Countershaft (front) sprocket also has a rubber damper on it... Aftermarket aluminum sprockets are MORE expensive.
An OEM Kawasaki KLX300 14T sprocket would most likely have the rubber damper... For about half the price at just over $12, a Yamaha OEM 14T # 5NG-17460-00-00 like I had on my 2002 WR426F has the rubber damper. It's also the same JTF 565 fit. (SC: self cleaning/lightweight)
http://www.jtsprockets.com/catalogue/sprocket/JTF565
Then there's Yamaha's WR450's OEM rubber damped 13T sprocket # 5TJ-17460-00-00
Rubber damped steel 14T: 5NG-17460-00-00 SPROCKET, DRIVE $12.65
Rubber damped steel 13T: 5TJ-17460-00-00 SPROCKET, DRIVE $12.56
Ninja 650R sprockets fit as well, available down to 12T:
Sunstar 520 Front Sprocket | SS3251x
Pit Bull Front sprocket | PBI00470-0xx
DrivenUSA Lightweight Front Sprocket | 2058-xxx-xx
Wait........
You mean to say purchasing the V wasn't a life long commitment!?
I don't believe I've ever seen a front sprocket made out of Aluminum. Rear, yes. For a streetbike, I'd stick with steel. They also make some lighter steel sprockets, I forget the make, but Motomummy sells them.
Wait........
No it does not. It is just that I have not seen another consumer product other than motorcycles that people are so fickle about. Purchasing one, only to get rid of it even before the end of the first summer. Always looking for the "perfect" ride.
I definitely am happy to pay attention to the ride itself. I do not care too much about the machine that I am on. Then again, this Versys is my first motorcycle. Perhaps I just chose the perfect bike. Then again, I don't care. I am going to keep riding.
Reactions: OKJohn
1 - 18 of 18 Posts
