1 - 11 of 11 Posts
I bought the new cowl for the right side of my gas tank. The old one was scraped from a low speed dump. But the decals are seperate.
Has anybody experienced putting on new OEM Kawasaki and Versys decals?
Does a dry application work or would you recommend the lightly soaped water solution method?
Thanks in advance!
Soapy liquid is the best way as it enables you to slide the stickers around to get them in the perfect position. I have a small rubber squeegee that I use to work from the centre out to remove any bubbles. Never failed using this method.
The company I work for just applied a new 12" square decal on our cargo vans. The method used was Windex and a squeegee. They are holding up nicely.
I, too, have scratches on my right cowling (previous owner-fell over in garage), and thought I might replace it and decals. But I think I'll just get tank panniers instead.
~ Wes
Thanks for the comments. I was leaning toward the "wet" method. I had watched a couple youtube videos about it. I will go that route.
I hate riding a scratched up bike, unless it is a dirt or true dual-sport. Then they are battle scars. :)
A naked tank cowl is a blank canvas...good time to consider something other than Kawasaki. See examples in this thread.
You are right, very cool stuff!
But I actually like the stock decals. (Yeah, I know, I'm boring ;) )
And I already bought them.
That reminds me. Thanks to whoever it was that suggested partshark.com. :goodidea:
It was cheaper for me to buy my new OEM parts there than Bikebandit with the AMA discount.
Plus I found out that partshark is part of Flatout Motorsports right here in Indy, so I helped support a local company. :)
I had to replace mine on the left side for the same reason, and since they are pressure sensitive adhesives there is no need for water. I measured carefully the good side and used masking tape to locate the spot. Sort of a cheap registration job. I work at a place that for 50+ years has made millions of adhesive backed nameplates so I knew how to handle them. Good luck.
Don't know if I'm the only one, but I did recommend PartShark. You're welcome :thumb:
This dry method worked very well. I measured and taped off the area for both stickers. Started at one end and pushed and rubbed it down a little bit at a time. No bubbles and looks great. Whatever the adhesive is that they use it is very cooperative. I usually end up with bubbles under decals. Not this time. :)
Now when it warms up a bit (which means the garage will warm a bit) I can get the tank and radiator cowls replaced and the T-Rex sliders on.
Going to be ordering some Giv v35 side cases soon. I already have the PLX rack on the bike.
Man I am ready for Spring!
(BTW - I am in Indy and the temp dropped drastically after last weeks Super Bowl. Low 20's F)
It's been cold here today too. About 25°. But this week we are going to high 40's so I may be on the road here in CT. Glad to hear you got the decal on ok. I didn't think it would be a big deal.
1 - 11 of 11 Posts
