1 - 4 of 4 Posts
I just completed a review and installation video for Dyna Beads, in case any of you are interested. I am now using them in my tires and so far, so good!
No Video
Been using them in most of my bikes for the last couple of years . they seem to work pretty good. I bought about 5lbs from fox industries I think it was 40.00 including shipping.
I used them on my EX500. They worked fairly well up to about 85mph, then it started to get a little jitter in the bars. Maybe adding a little more weight would have fixed it, but it wasn't a big enough problem to worry about.
Been using them for years, altho' I now buy the beads in bulk from Fox Industries. MUCH cheaper!:yeahsmile:
Word of advice - IF you don't have the special DynaBeads valve guts in your valve stems, suggest you ALWAYS give a short burst of air into it before you check pressures. That will dislodge any beads that might be in position to keep your valve from seating (slow leak). By doing this I've never had a problem.
:goodidea:
1 - 4 of 4 Posts
