1 - 4 of 4 Posts
for various reasons, I find myself turning on the key while the bike sits in the basement, quite often, but not starting it. then I got to thinking,i sure hope im not causing the fuel pump to put gas into the t.b. I do hear the pump running, or at least I think that's what it is, for a few seconds every time I turn the key on. does anyone know if there is any harm in this? I sure don't want to be dumping fuel into the engine every time I turn the key on and don't start it.
No harm done. Fuel pump is only pressurizing the fuel raii up to a set pressure. No fuel is being injected before ECU gets a crankshaft position signal once you start cranking engine to start it... You do want to make sure you keep your battery charged up to reduce sulfation and degradation.
yeah, that's good to know.---- I have a plug for my charger that stays on the bike.i keep it plugged up pretty much all the time.-----thanks for the info------
Dale - some years ago the battery on my KLR dried up over the winter, plugged into a "float" battery charger for 5 1/2 months. Since that happened I run my chargers thru a 24 hour timer, set for 15 minutes in 24 hours, and have not had any problems since.
1 - 4 of 4 Posts
