Does anyone know which brand of antifreeze to use which is safe for the V?
The Manual says Permanent type of antifreeze?:confused: what does that mean??
Green. Sorry I had to.:p Realy almost any anti-freeze wil do, just make sure you mix in some water with it.
I heard that some additives in car coolants can block the radiator pump or something?? Anyone know anything about this??
There is no permanent type coolant... Kawasaki means long-life (4-5 year) coolant, and the recommended replacement interval is 3 years/36000 kms (24000 miles). Mix 50/50 with distilled, demineralized or deionized water with bittering agent. Total capacity is 1.2 litre.
http://www.prestone.com/enlarged/index.php?product=prestoneAntiCool3&name=Extended+Life+Antifreeze/Coolant
http://www.nulon.com.au/products/Long_Life_Concentrated_Coolant/
There can be some problems when mixing different types of coolants that have incompatible additives...
Whatever you use, make sure it is rated for aluminum block and radiator.
Maloy
