1 - 20 of 63 Posts
What do you recommend for chain lube? I need to buy another can just wondering what I should try next? I would live to try the Dupont Chain Saver as it seems to be highly recommended but cannot buy it where I live.
So far I have tried Castrol chain grease (lubes well but is grease so attracts dirt and flings off a little), PJ-1 clear (does not seem to lube that well), and Maxima Chain Wax (best so far, low fling off and adheres well). The only issue with the chain wax is it requires some effort to remove when cleaning the chain as it adheres like a rubber coating.
Also has anyone tried generic dry teflon lubricant? Would this work? Also I park the bike outside at night so chain rust is a consideration. Would a dry lube prevent rust?
I'll start it.
I only use WD40 every couple hundred miles when I put it up.
Getting 20,000 miles per chain and sprocket without slinging crap all over my bike.
No more lube for me, EVER.
Let the fun begin.
And I was the fastest sumgun I ever knew.
I'll start it.
Let the fun begin.
And I'll start the counter-argument....
WD-40 isn't a lubricant, it's a Water Displacement treatment... yada yada yada...
:funnypost:
If you read the specs, Dupont also contains moly, nothing personal, and it has been repeated many times on this forum, WD-40, doesn't contain anything that will reduce wear or friction. My sprockets and chain are at 16000 original KM and no sign of wear, all those KM I have used Dupont multi-purpose or chain saver.
My son used probably 12 different lubes, and they are stored in the same place as the Dupont, they haven't been touched in 4 years. He used these on a mountain bike chain when he belonged to a bike club, switched to Dupont when it first came out, haven't regretted the move, plus it is about half the price of other lubes.
For those WD-40 fans, check out what they have to say about it, they probably don't have a clue what they are talking about on this product
:funnypost:
http://www.webbikeworld.com/t2/motorcycle-chain-lube/chain-lubes-2010.htm
I simply cannot ignore people who say that their chains last a long time using only WD-40 (which is not a lubricant, I know).
I now use the DuPont stuff.
The issues I had with using 90-weight gear oil was all of the dirt on the chain and the swingarm. My chain and sprockets lasted about 18000 miles. I do not know if that is good or bad. To me, it does not seem too bad.
At this point I would just use what does not cause a lot of dirt to accumulate on the chain and swingarm. When I run out of the case of the DuPont stuff I bought online, I will likely just go to WD-40.
Don't know if WD 40 is good or bad for your chain but it does have a lubricant in it. 15+% mineral oil (light lubricating oil) I'm quoting wikpedia.
I've used ATF and 80W90 gear oil so far. Didn't quite like the gel type lube from Sikolene. ATF was used like a Scott Oiler system, but this oil doesn't stay on very long and washes off too easily when it rains. A continuous feed is required for consistent lube.
Gear oil OTOH is sticky and stays on a lot longer but also attracts dirt. I put some gear oil on my recent oil on the chain on my last 400km of travel, went through heavy rain, and when I check the chain, the oil is still present, and the chain did not stretch that much. Compared to another trip of 600km where at each stop, I put in ATF, and when through rain, the chain was very stretched when I reached home. It was pretty loose, and was knocking against the stock muffler, and vibes were higher. Chain was dry and some of the side panels were showing rust.
Yep, I use WD40 and get good mileage from chains and sprockets.
I figure 20k miles the way I ride is great. I bet you guys that lube claim to get 40k miles or more.
I just love those who absolutely are sure about how bad it is and how it has no benefit.
I feel the same way about your nasty lubes you use.
And I use Rotela oil instead of $12 a quart special jimmy motorcycle oil.
If you don't mind a little cleaning use any lube you want.
Alot of people are using the Dupont or other with Teflon or something in it.
I just happen to like WD40.:clap:
Jose, I'm with you mate. I now use nothing but WD-40, but do pay close visual attention to the chain's condition. :thumb:
You'll LOVE it! 54,000 kms on OEM KLR chain; 37,000 miles on 2008 OEM V chain (STILL on!); and 18,000 kms on my '09 chain.
NOTHING but WD40 and a wipe-down after, and I do it after ANY longer ride of 50 miles or so when I get home, but on a LONG ride I'll respray sooner in rain, but at least once when I pull in to camp while the chain's still hot.
BTW - buy your WD40 in the gallon size: cheaper, and higher % of the lube, LESS carrier than in the spray bombs!
I feel the same way about your nasty lubes you use....I just happen to like WD40.:clap:
:thumb:
I use WD 40 for cleaning and Castrol chain wax for lubrication, works really good.
Dupont Fyi please read
For those of you who do not already know. The Dupont in the blue can has changed formula, it is not the same.I am a long time user and yes there is a difference.Dupont has the old formula in a yellow label can, marked as chain lube SAME PRICE. You can buy it at any Walmart which has the section in automotive for cycles and atv 's.This is usally the larger stores or supercenters.I would also do an online search for it, starting with Duponts multilune website. The new stuff is darker and flings a bit the chain lube doesn't fling and is light colored.
Belray superclean for street & dualsport. Expensive but sticks well & sheds dirt relatively well.
Tried the wd40 thing back in 03 for dualsporting after reading of a dakar team using it. Seemed to work well & was good for keeping the chain clean but found myself having to apply way more often than regular chain lube/wax.
yup. i have seen people use wd40 to clean their chain. they dont lube their chain, just keep it clean using wd 40. this is for dirtbikes, where you dont want dirt to cling to the chain. many lubes attract dirt, except for the dupont stuff, which is now changing....CRAP!
for my xcw, i usually clean the chain with wd40 and then lube with the dupont stuff.
ditto for my versys, but i dont clean as often.i dont know what to use when the dupont stuff runs out...
1 - 20 of 63 Posts
