1 - 20 of 32 Posts
Yes, I searched and read a few responses...but everyone seems to have a different take.
So, I changed the front tire, the brakes work but the ABS light is constantly "ON". Did I damage the sensor, or is there a spacing issue, etc?
Year of bike, tire size and brand installed, did you reinstall the collars and seals correctly. Did you move the bike more than 50ft if not ABS will remain on till both wheel move forward. Did you over grease the brakes and got grease over the censor, the brake disk has hash marks close to the axle is it dirty? did you balance the wheel if not the fast wobble will simulate gravel roads and ABS will stay on and only restart calculation when bike is restarted and ridden.
(2007-2017 V650 service manual)
Even when the ABS is operating normally, the yellow ABS
indicator light (LED) may come on under the conditions
listed below. Turn the ignition switch off to stop the indicator
light. If the motorcycle runs without erasing the service
code, the indicator light may come on again.
OAfter continuous riding on a rough road.
OWhen the engine is started with the stand raised and the
transmission engaged, and the rear wheel turns.
OWhen accelerating so abruptly that the front wheel leaves
the ground.
OWhen the ABS has been subjected to strong electrical
interference.
OWhen tire pressure is abnormal. Adjust tire pressure.
OWhen a tire different in size from the standard size is being
used. Replace with standard size.
OWhen the wheel is deformed. Replace the wheel.
the ground.
interference.
2018 Versys 650. 11,000 miles.
It's the right size tire. I took it down to the local gas station (about 2 miles) and got it up to 60 mph. I feel no wobbling and the front end ran straight and didn't pull.
The only thing was when I first started it up and backing out of the driveway, when I squeezed the brakes there was no pressure on the first squeeze. The second squeeze I was back to normal.
Should I bleed the brakes?
***Oh, and the brakes worked fine on the ride.
WHENEVER you remove a wheel, then re-install it - it's a GOOD IDEA to squeeze the appropriate brake lever several times to re-seat the pads, so you don't run into the surprise of trying to stop but there are NO brakes...!
you got a 2018 bike your service codes shows up on the dash. No Ground any wire needed. ABS will blink Long and short and repeats for like 5 min. Long is first number short is 2nd number.
Pre-Diagnosis Inspection 2
1)Check the yellow ABS indicator light (LED).
o Does the indicator light come on with the ignition switch to ON? NO [Check the power source wiring and meter unit.]
2)YES, Drive at 10 km/h (6.2 mph) or above for one minute or more.
3)When the motorcycle is running, does the indicator light go off? YES [ABS is normal.]
4)NO!!!! Count the number of times the indicator light blinks in the self-diagnosis mode to find the service code.
I just started her up. I "grounded" that terminal as per the Service Manual (Section 12-41). After turning on the ignition with it grounded, the ABS light blinks once and holds-then 2 short blinks, then repeats.
I'm assuming this is Code 12, according to the Service manual (Section 12-45)???
If it is it says, "Problems- Start code (not fault) | Light State - After starts, turn off"
I have no idea what that means!
NEVERMIND!!! I'm an idiot!!! Yep, Crimson Apple nailed it. I have the wheel installed on the wrong side. Son of a .... Back to the No-Mar for another tire change. Live and learn.
***For what it's worth, this is my first ever ABS bike.
That's normal, it's reading your ABS starting code, need to ride to get the other code. and did you check if the metal hash mark on the Brake disk is on the left side of your bike. :grin2: If it is that's the problem and will make me giggle a little bit. (check my picture does it match.)
Discussion Starter #14
If you can't laugh at yourself, who can ya laugh at?!?!
Man, I miss the simple bikes without all that ABS/Relays?LED's/blah, blah, blah... :|
You still can ride the bike as long you don't brake too much on the front disk so your pad will not be conformed/shaped wrong. Also no ABS brakes, if you are going to ride it make sure your front tire is in the forward position if not, easy fix, no need retire or blanence just put on a front motorcycle stand change it and torque the right lbs you be a okay. If you got it done with cycle gear is free for redo and tell them nicely they didn't use a service manual. :grin2:>:)
Discussion Starter #17
I'll change it out myself and get it right. I think I was so in-tuned to just getting the tire mounted to the rim that I never paid attention to what side was what. I went by the tire arrow and the rim wheel stripes.
:surprise: You mean Invader nailed it! Crimson Apple then quoted my first post.
Apologies!!! Invader's the winner!!! :grin2: :grin2: :grin2:
Seriously, to ALL, thanks for the help. I was trying to do too much, too fast. Wasn't thinking this thing through.
...I have the wheel installed on the wrong side....
I ALWAYS look at the small DIRECTIONAL ARROW on the LEFT side of the front wheel, just IN from the fork - check the pic I just took. (I 'highlight' it w/ black felt-marker.)
Discussion Starter #19
OK, I changed out the tire, then remounted, then put the wheel on the correct side of the ABS.
And it's official...that axle nut can kiss my ASS!!!!! I've rubber mallet'd it, I've finessed it...NOTHING WORKS!!! It won't catch the thread no matter what I do. I've wiggled, lifted, pulled, pushed the tire...NOTHING!!!
I'm done for the night before I pull out the grinder and start sawing that thing into small pieces.
1 - 20 of 32 Posts
