1 - 3 of 3 Posts
Hello All!
During autumn I've discovered ABS alarm on V (but w/o any degrade effects on engine etc.), and currently after consulting V service manual, I've realized that there a lot of possible problems (lamps, fuses, switches, battery; and may be more bad things - ignition switch or ECU). :(
Does anyone experienced such trouble? What it was in your case (most of)?
What was replaced?
Thank you in advance.
:welcome: Mmax,
Did it come after you did some repairs or it just popped out (ABS alarm) one day?
Have you tried going to the dealer to reset it?
For what it's worth, check your battery voltage.
It was a common problems on BMW bikes where if the battery voltage was less than 12.4 V, the ABS light would come on.(sorry, off track here) when starting it up.
Charge you battery and give it a go.
1 - 3 of 3 Posts
