1 - 20 of 26 Posts
Administrator
If you have 2 connectors they are for OBD (On Board Diagnostics) system, 1 is for ECU and the other is for ABS which should be black. (Stand to be corrected).
Would you know If I am correct in assuming there are no auxiliary power connectors under the seat.
Location is in your owners manual, a fused I think 5 amp output in two locations, common to accessories such as heated grips, fog lights and USB / 12 volt outlet .
Discussion Starter · #8 ·
I am trying to locate another one as these 2 are already used for heated grips and 12 volt outlet as stock on this bike. Thanks for the reply
Not that I am aware of, but you can created your own switched supply using a fuse and a relay. I run all of mine from under the seat using an inline fuse and a relay so that its controlled from the ignition switch.
Discussion Starter · #11 ·
That's what I would like to do but I'm just curious as to where you tapped into the power source that is controlled by the ignition.
Aux. Power/ How To Forum
I will post a link and any questions you can add latter. The simplest method of triggering is using the tail light and frame ground. A second location in front I use the aux. circuit and ran a 30 amp to a distribution block and a relay, then branch circuits at 10 and 15 amp.
I realize this is the V1000 thread but for now we don't have enough posts to make a separate thread, the idea is the same for all.
https://www.kawasakiversys.com/foru...-relay-power-outlet-install-2015-earlier.html
https://www.kawasakiversys.com/foru...relay-fz1-oxford-heated-grips-aux-outlet.html
X300 thread
https://www.kawasakiversys.com/foru...-power-socket-12-volt-lighter-plug-style.html
Reactions: dlars and 52Degrees
I like the idea of triggering a relay from the tail light. That makes sense.
Tell me where you are on the bike and I will tell you what to use. For instance, if where I have my distribution block I could have used the horn, as it is keyed live, the horn button is the ground .
Reactions: 52Degrees
Discussion Starter · #17 ·
X300 thread
Perfect, thanks for all the info
Discussion Starter · #18 ·
Thanks to everyone who supplied information and commented on this thread, greatly appreciated.
I used the license plate light for the relay signal wire.
I used the Battery terminals for power and ground.
I would not recommend drawing power off of any of your signal lights or anything that you need to remain powered. If you blow a fuse you could find yourself without lights. Blowing the fuse might not actually be the result of faulty wiring or a short, it could simply be the result of drawing too much current for what the system being tapped is designed for.
Since you are going to the battery, I would also recommend that you utilize an inline fuse. Pick a fuse that is just above what you intend to draw, not the maximum of your wiring.
Discussion Starter · #20 ·
For sure. I am just tapping into an existing ignition powered source to power the relay, not the actual accessory.
1 - 20 of 26 Posts
