1 - 14 of 14 Posts
The owners manual says the oil quantity is 2.4 quarts in the specifications chart which is correct. In the oil change section it says 1.9 quarts with a filter change and 1.7 without. Just something I noticed and thought I'd pass on. Same info in my friends Ninja 650R manual. :interesting::huh:
There is NO mistake in the manual. The oil capacity in the specifications will NEVER equal the amount that comes out during an oil change. You will not get every drop of oil out. There will always be some residual oil left in the crankcase. Around 1/2 of a quart sounds about right.
correct... when and if you do a valve inspection and take the top cover off, you will see around the cam area quite a few pockets where the oil pools and does not reach the sump.
The sump also have a few pockets that pools some oil and it does not drain.
There are probably a few more places where oil is trapped in pockets in the engine.
Bikes are rated with a weight that is dry - no fluids... a fresh virgin engine never seen oil. This is probably the 2.4 quart dry weight capacity needed.
Once you do oil changed the capacity is a suggested quality only.
Based on how much oil my engine swilled out, after it was drained and the filter pulled, as we swung it onto the bench with a come-along, it bled oil all over, maybe not a half quart, but a fair bit. I bet it's all out now... :D
Unrelated, the KLR forum crowd (many of us in a previous life) pretty much all were in agreement that filling the oil to the "line indicated" for the glass window 1/2 way ("Goat's eye") was insufficient, and they all (we all) commonly would fill till the "eye" was just turning totally black.
No so with the 'Vers?
Manuals are sketchy- when it says the KLR has six speeds, it' hard to trust them about anything after that.
When changing oil my Concours, I'd just put in the appropriate amount and Bob's your uncle. I never looked at the oil window. Is that what you guys do with the Vers? Dump in two qts and call it a day?
I put in 2 qts and then check the glass. I'm always leaning the bike back and forth to try to get as much oil out as possible when draining. Just me.
I put in about 2 quarts. Then after my next ride, I turn off the motor, wait 5 minutes, stand the bike up, look in the little window, then top off the oil to get it near the top of the range indicated in the window. I've read on the forum that keeping the oil topped up could help cool the stator. Some V's have stator overheating problems and failure.
Using the sight glass is tricky. The bike has to be perfectly upright, on level ground. I sat a small level across the gas cap, and had my wife tell me when it was bubble perfect, the first time I did an oil change. Measured how much I put in, and use that as my guide. A couple of degrees lean of the bike in either direction, and the sight glass oil level is completely off. Also, whether you use a long or standard oil filter makes a bit of difference.
Was on a ride with a friend a few months ago, and while stopped for a minute, bikes off, he glances down and tells me that my oil level looks dangerously low, barely showing in the sight glass. I position myself as perfectly as I can, and stand the bike as level as my eyes will allow. "Check now", I say. "Never mind.", is his reply, after he sees the oil a hair below the top fill line.
I also believe that there are only two dangerous extremes when it comes to oil: Way too much, or way too little. Two or three ounces on either side of the perfect amount, is NOT going to result in catastrophic failure. Pick a "round about" amount, and ride the chit out of it.
Found this on page 7-8 of the 2015 Versys 650 manual:
Oil Lever Inspection
"If the oil level is too low, add the correct amount through the oil filter opening".
1 - 14 of 14 Posts
