21 - 31 of 31 Posts
Did you reset the codes ?
Code 62
Subthrottle valve actuator
malfunction, wiring open or short
Do you have the service manual?
If you remove the tank and the air box can you see the butterfly / subthrottle valves open and close when you switch on the ignition
Discussion Starter · #22 ·
Code 62
no i do not have the service manual and yea tank is off valves are in closed position when i turn key they make the wierd buzzing noise i can tell they are trying to open but they dont they just kind of flutter
Service manual says for code 62
62 Subthrottle
Valve Actuator
The actuator operates
open and close of the
subthrottle valve by the
pulse signal from the
ECU.
If the subthrottle valve actuator fails (the
signal is out of the usable range, wiring short
or open), the ECU stops the current to the actuator
Sound like you might be on to something
Well it sounds like your sub throttles are not stuck but they can't tell where they are. Maybe they have their own TPS that is bad or a pinched wire for that stuff somewhere.
Discussion Starter · #25 ·
62 Subthrottle
Valve Actuator
ECU.
so replace the valve actuator?
Discussion Starter · #27 ·
okay so o got her to start finally but every time she goes to an idle the motor cuts off, im stumped anybody got an idea
You mean it only runs if you hold the throttle open some?
Idle could be set too low...
All codes are gone?
You can get it to run at 1250rpm holding the throttle?
By the sounds you have idle set too low. 62 code means your bike wont automatically adjust idle RPM and you are in much greater risk of stalling (or cut off)
Ive been living with code 62 for 2.5 years now and it's a small inconvenience when you have a cold engine at the start of the day but its managable
When I startup the bike idle RPM is around 0.9/0.85 which is borderline stalling. Once bike warms up idle goes back to 1.3 RPM. I can adjust the idle screw so would initial cold idle RPM would be like 1.1 but then it means warmed up idle will become around 1.5-1.6 which is a bit much
I was looking just to replace the bodies several times but I didnt replace them due to lack of decent used parts around here. And it's also relatively expensive - I estimate $200-300 for used part or $1000 brand new
But onto your point - just crank that idle screw up and see what happens
21 - 31 of 31 Posts
