1 - 4 of 4 Posts
Added a new 650 to the fleet for a light runabout in Central Texas. Cannot get the %^%(*&$# headlight plugs loose....twist? pull? hidden clip? Sorcery?
They are a prick to get off the 1st time I ended up using a screwdriver to lever them loose. You do have to use some strength to get them off. Try not to bend the pins.
Also Kawasaki uses an adaptor on the headlight so you remove the plug then once you get the bulb out they have a black plug on the back of the bulb.
1 - 4 of 4 Posts
