1 - 11 of 11 Posts
I found these, has anyone had any problems here?
Most Recent Recalls For KAWASAKI KL650E
Vehicle Component Manufacterer
2009 KAWASAKI KL650E ELECTRICAL SYSTEM:WIRING Recall
Units affected: 16167 KAWASAKI MOTORS CORP., U.S.A.
Report Date: 2009-02-20
Summary: KAWASAKI IS RECALLING 16,167 MY 2008-2009 KLR 650 (KL650E8F/L, KL650E9F/L) MOTORCYCLES. WIRES IN THE WIRING HARNESS MIGHT BE DAMAGED DUE TO RUBBING CONTACT WITH A PORTION OF THE MOTORCYCLE FRAME.
2009 KAWASAKI KL650E ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE Recall
Report Date: 2009-02-19
Summary: KAWASAKI IS RECALLING 16,167 MY 2008-2009 KLR 650 (KL650E8F/L, KL650E9F/L) MOTORCYCLES. THE MUFFLER ASSEMBLY IS SECURED TO THE FRAME OF THE MOTORCYCLE BY TWO BOLTS. IT IS POSSIBLE THAT HEAT EXPANSION CYCLES OF THE MUFFLER, COMBINED WITH VIBRATION FROM VEHICLE OPERATION MAY CAUSE LOOSENING OF THE MUFFLER MOUNTING BOLTS.
Shouldn't Kawasaki be notifying the owners of these recalls? I am the original owner and I have received nothing from Kawasaki.
I thought a service bulletin was just to inform dealers of a potential problem .But Not an actual recall. You can check recalls here.
http://www.motorcyclistonline.com/motorcycle_recalls/04/2008/index.html
Exactly, there is not recall or we would have been notified. But good information to have, so we can fix or watch. I personally have not been
back to the dealer, but am going Friday to have them give me their fix on the swinging loose mirrors. I will ask them to check the wiring harness too.
I think that recall is for KLRs not the V. The V's are KLE650, whereas the KLRs are KL650E, the last letter being for the model year.
Disregard this post, I see what is apparently a recall on the KLR, not the KLE. Apparently, the Kawasaki KL650E is the KLR, if you read the last part, they refer
to the KLR. I found other blogs on websites about exhaust and wiring harness recalls on the KLR. KLR owners probably are already aware of this.
I was starting to think that kawi was having some serious problem with their exhaust and wire conception
I just sold my 2009 klr and I had received, during the year, the same recall
LOP
Just a heads up
having just had my bike serviced, the mechanic observed that there was sign of rubbing on the wirign harness under the tank. unfortunately I didn't see the wear so cant tell precisely whether its the frame or the tank thats causing the problem, I'd guess the tank. as a prophylactic he has put some extra layers of insulation tape on the wiring to delay it developing into a problems
Thanks for the heads up!
Just a heads up
That's something we should all check, or have checked, when cleaning the air filter or having other service done.
All in all, it seems that finish problems with the Vee are few and far between. I've heard a couple of other people mention wiring rub, there's the slight problem with loose mirrors on some bikes, the fairing buzz, somebody mentioned a pinched clutch cable caused by a guide clamp, a stock seat that sucks - that's about all that I can think of. I wish that auto manufacturers could get it together that well.
1 - 11 of 11 Posts
