1 - 5 of 5 Posts
Wire found at Lowes , could not find at Home Depot Very easy to work with, I reversived the bolt clips on top of the radiator to hold wire.
I made something similar, but have 1/4" rubber gasket mtl seperating the mesh from the radiator tanks. That gives a little more buffer between the screen & the core + prevents the mesh from wearing into the tanks.
Thanks
Right now the metal is not hitting the rad. because I made the attach points large enough not to hit the rad BUT adding some rubber around a the edges may be a good idea,
thanks cb
1 - 5 of 5 Posts
