Just installed the rubber 15t sprocket.
On reassembley, I’ve noticed a dragging noise coming from the cover at the sprocket. I’ve removed cover and noise goes away. I reassemble and noise is there. I’ve tried to adjust the best I can but can still hear minor scraping. Anyone have this issue? Thanks.
Discussion Starter · #3 ·
Fixed! I have to really push it toward the front of the bike and lock it down. All good! 🤙🏽.
PS. YOU DO NOT HAVE TO LOOSEN THE REAR TIRE TO INSTALL THE FRONT SPROCKET. I removed sprocket nut, pulled off sprocket and chains together, added the necessary shims, installed new sprocket and torqued sprocket nut. Was done in about 18 mins.
