1 - 10 of 10 Posts
I got my new 09 Versys a few weeks ago and put about 110 miles on it.
I set out to set the sag and rebound on it today. I found that the rear was set about right. It has about 5-7mm free sag and 30mm with me on it (I weigh 235).
The rebound seemed just right as well. This surprised me given that they're supposed to be setup for someone that is 150lbs. The front however, perplexed me a little. Initially sag was only about 15 mm so I rolled out (counterclockwise) 2 1/2 turns on each fork. It lowered the front end a little, but sag was still 15mm. That didn't seem right, so I stopped there. I also looked at rebound on the front. Holding the front brake and pushing down in the plane of the fork angle and letting go, it rebounds with a few bounces at the end like its set too soft. But if I hold brake and push down then release brake as I release force, there is no bounce.
So the questions are whats up with the front sag? Do I just need to roll the adjustments out (ccw) farther? And whats correct with the rebound, holding brake or no brake?
Thanks and I look forward to some words of enlightenment! :)
:welcome: Jcstratt,
Sounds like a sticky fork. Some ideas:
1. Is the fork alignment straight?
2. Check the space/ gap at the fork clamp/braces are the same.
3. Maybe changing the fork oil could help.
4. The spring seem to be soft, try hardening/tightening the spring.
5. Maybe the fork seal is sticking. Try shooting some silicon spray at the joint
to see if it helps.
The front fork adjustment on only on the right fork.
Thanks for the link, Gustavo. I see now where I was "missing" 15-20mm's in my measurement of the front.
The question remains about setting front rebound. Which is the correct method for the initial setup....
1. hold front brake, push down thru plane of forks, release forks and observe the rebound with the front brake held? I get lots of bounce this way.
or
2. hold front brake, push down thru plane of forks, release forks and brake at same time and observe rebound? I get no bounce this way
or
3. use no brake at all and butt the front wheel up against a wall (or other solid object) for the process? I haven't tried this one yet, but I suspect it will be much like holding the brake thru the whole process.
Thanks again for the replies!
going for the test ride is the best way to test imho, see how it feels to you but use the same circuit and speed everytime you adjust.
Suspension setting is very personal to each individual and its more of a feel rather then technical.
You need to get the right setting for the bike and you, to be one on every turn and bum. So get started by a marked setting and then twit it along the way to suit you style and feel.
Factory setting is for 70Kgs weight which is BS.
When you release the brake, does the bike move back? It does for me, which is why it doesn't bounce as much (some of the energy is converted into bike motion instead of fork motion). Keeping the brake on while compressing and releasing yields better results (unless you are capable of compressing and releasing the spring without any bike movement without the brake, like when using a wheel chock).
But, like our Kiwi friend mentioned, eventually, you have to test ride it and see how those settings work in your real world conditions. You may have to fine tune based on the types of roads you encounter on a daily basis, which is where that test loop comes in handy.
Gustavo
It turned out that the rear sag was set at 34mm and the front is 37 after 2 1/2 turns out.
Rear rebound seems spot on, front bounces some. Adter riding it around, it feels a bit smoother, but a bit more uneasy. I will probably dial in a few turns of rebound and see what happens.
Thanks for the tips on the front sag! :)
1 - 10 of 10 Posts
