Okay, so backstory time fellas. I bought a wrecked 07 ninja 650r bike. (The guy backed into it with his truck and let it sit for 9 years, until i got my hands on it. He claimed it ran good and all that. I got it with no keys and the top of the tank was litteralt rusted apart. I bought a battery, a wrecked tank from eBay, and a rebuild kit for the fuel pump. I threw a flathead in the ignition and turned it with some pliers. ( ok so I never should of did this, but considering i did this this in mind of ill just replace it come tax/spring time when I actually get to ride it) - I just wanted to know if it ran. - So then I fixed the tank, rebuilt pump, changed oil, (added coolant, I should of replaced) dont know if that caused any problems.. But threw it all together with some fresh gas, bike ran amazing.
Fast forward to a week or two everythings just sitting in the corner of the shop protected from moisture. I take the tank off and pull out fuel pump to get a nice black laid down on it. Pulled chain and set it oil. 1 and a 1/2 week later I put it all together turn it over cranks, fires, gets to idle and dies. Litteraly every time! Dies after 1 second of starting bike and im completely lost. Idk what else to test, bike primes pump great, lots of fuel shooting out i threw two spark plugs at it, no changes. Anybody got any leads? I messed with lay down sensor and kickstand sensor but doesnt change anything(have not tested those switches) ive held in clutch, made sure its in neutral(lights up green N) held brake, made sure seat was locked i got nothing.
The only other thing I messed with was my stupid a** trying to not mess up ignition so at somepoint I tried jumping wires around the gray wire. Dont exactly remember what I did, but concluding up to now, I went out and bought a toggle switch and a 100 ohm resistor 1/4watt.
My brain hurts after trying to lay this all out, ill try to reply fast as possible thank you for youre time
