Hello
Lets make this people who have BosterPlugs share their thoughts.
I bought BoosterPlug, and here here is my Findings...
-Yes! worth the money!
Why`? i noticed the difference after few minutes of riding...Firstly, first gear is not Grumpy grandpa that cannot decide what to order..instead, the 1,2,3 and all the gear on all the RPMs are now
Nicely smoooth. you will know what smooth means instantly after you install BP!
Basically, Throttle pick up, And drop is smoother, None of that GO, STOP, GO GO GO STOP STOP STOP....thing..more linear curve id say. you can add 10/20/30 more throttle and it will just increase speed,
Unlike before it was ON/OFF throttle. you either accelerate, Or Deaccelerate. now you have smooth curve. No jerkiness
TL;DR i cant explain but i see,smell and feel the difference. i can do 25km/h at 2nd gear smoothly. it does Not do that ON OFF thing where it injects fuel,then not and then injects fuel.....it just works properly now.
Difference is small,No, wrong choice of words, its Subtle! (but so Necessary, BP is Needed for better riding,i find)
I took BP off, to see what i will see, DAYUM! how did i ride the bike before? instanly installed BP back...
SO....when throttle works good, no complaints. You just ride, and not notice anything bad.
When throttle is jerky, you know about it and Dislike it...Luckily for us, BP works.
Easy install. You will figure it out easily.
Worth 150 coins ? For me, Yes! (Try to Race on a track with out BP, Or ride twisties with out BP, youll see difference) Throttle accuracy is now better! as if more steps, rather than on 10%/30% 70% and 100%
now its like 10%- - - - - - 100% all in between. more Gradual.
