Kawasaki Versys Forum
(https://www.kawasakiversys.com/forums/)
- General Discussions - V-650
(https://www.kawasakiversys.com/forums/162-general-discussions-v-650/)
- - New Versys owner need some HELP !
(https://www.kawasakiversys.com/forums/162-general-discussions-v-650/81393-new-versys-owner-need-some-help.html)
Hi everyone, i am a new member here and a new versys owner, i bought a versys 650 - 2007, i like the bike a lot to be honest, its really cool, but since i bought a have a big problem that i cant solve my self, i have a problem with my bar, my bar its not straight, my left hand get very very tired during the runs, but only my left, the right hand is ok,,, and my left leg gets some tired,, i should say that the person that had before had put a new seat,, more lower than original,,, when i run the bike i see that the bar is not straight cause my left hand stays longer! now i dont know how to fix it,,, dont know where the problem is,,, is the front tyre,, the bar,,, or the seat ,, and i dont know how to fix my bar if it straight or not,,, please can anyone help , i will really appreciate a help and respect you all!
+ yesterday i made a test,,, i was driving with 50-60 khm,,, and left the bar without keeping it with hands,,, and the motorcycle wasnt going straight, it was turning to the left,, or moving to the left side,,,, i got really worried,,, cause it should go straight! what do you think guys,, cause this is driving me crazy ! :/ :thanx: |
If you suspect that the handle bars are bent, then remove them from the bike, put them on a flat surface to check them. If they are not bent, then follow the procedure for aligning the triple clamps (the clamps that attach the forks to the frame). BTW, my V does not have a seat belt. ;)
also, check the alignment of the rear axel / chain tension.
had your bike been dropped? or did the seller not mention that? afall can bend the bars easly and make one side be bent in more then the other... it could also just be that one of your arms is longer then the other (most peoples are, me left arm is over an inch longer them my right)...
and if your bike has a seatbelt you might have a problem...... |
I had to replace my bars. I could not turn it hardly with the low standard risers. So I got new bars and the vib-free riser, and it was night and day difference (of course it should come with the riser stock.)
Try posting a picture, may help to solve the problem. But it sounds like the left bar is bent causing it to be a longer reach to the controls on that side. The other problems you describe is a mystery.
Take something like a piece of tile that is FLAT, put it against your forks and confirm it touches in FOUR places, two per side. If NOT, your forks are "tweaked", and it's fairly simple to "un-tweak" them.
i wanted to mention the SEAT ,,, not the seatbelt :/// language mistake,,, yesterday i made a test,,, i was driving with 50-60 khm,,, and left the bar without keeping it with hands,,, and the motorcycle wasnt going straight, it was turning to the left,, or moving to the left side,,,, i got really worried,,, cause it should go straight! what do you think guys,, cause this is driving me crazy ! :/
The bike may not travel straight depending on road conditions, tires, added equipment, side to side loading dfferences, etc
Grip the tank with your knees when testing for balance, and you should be able to influence direction with body lean in either direction, even though the bike may tend to one side by itself. Most bikes do not go perfectly straight on their own. |
Public roads are graded for water runoff. One cannot ascertain misalignment very well by using a "hands off the bars" type test.
141 Attachment(s)
Wrt alignment I would recommend alignment of rear wheel using string method. See youtube video for how to. This is the most accurate method without exception as the extended string magnifies small changes
:goodluck: |
thanks everyone for the help... you are really a great forum,, thnx a lot to everyone that replied to this post :) respect all the riders here :) :D
I'm thinking fork alignment as well.
Hey, I like that "Tile Test" Ed! |
i made the fork alignment and it hast fixed nothing :/
Haven't you checked you rear wheel alignment yet?
1 Attachment(s)
Okay. To check your handlebar, rather than the hassle to remove them, take a measurement from the handlebar clamp mount bolt to the bar end on each side: Left lower bar clamp bolt cap out to end of left bar, then right cap to right bar end. If there is a difference in those lengths, then your bars are tweaked.
i did and the rear tire alignment and its the same thing :/
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by
Advanced User Tagging (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
