Kawasaki Versys Forum
Kawasaki Versys Forum (https://www.kawasakiversys.com/forums/)
-   Modifications - Cosmetic - V-650 (https://www.kawasakiversys.com/forums/186-modifications-cosmetic-v-650/)
-   -   Cutting the stock windscreen (https://www.kawasakiversys.com/forums/186-modifications-cosmetic-v-650/109498-cutting-stock-windscreen.html)
AbbottJ1 05-27-2016 08:18 AM
5 Attachment(s)
Has anyone cut their stock windscreen before?
I tried the screen upside down and really like it, but the one end of the screen is actually covering a portion of my headlight. I was thinking of cutting it.
What kind of saw would you use to cut that?
weljo2001 05-27-2016 10:50 AM
I drilled holes in a stock shield and a Givi with no issues. If i were going to cut one I'd use a Dremel. Since you have on old shield you might want to practice on that if you have any doubts.
ATYC 05-27-2016 11:34 AM
http://i347.photobucket.com/albums/p...pseb20e0cb.jpg
I rode with the stock shield flipped and in the lowest position for a long time. The little bit of reflection never bothered me and I thought it looked and worked fine.
Most of the time now I used the cut down stock screen in the photo. I cut it with a Dremmel. It was tricky because the cut off wheel melts the screen too, but it worked out ok. Needed some sanding and any imperfections are pretty much hidden by the fact I painted the back side black. If you paint, learn from my rookie error and mask the whole front. I got some overspary on the front corners so they are not as smooth as I'd like, have a bit of texture.
http://i347.photobucket.com/albums/p...psb057a76e.jpg
silviefox 05-27-2016 11:46 AM
hack saw. also put down some tape on your cut line to help reduce the chances of cracking
fasteddiecopeman 05-27-2016 12:51 PM
What kind of saw would you use to cut that?...
I used an electric jig-saw on LOW speed after putting duct-tape onto BOTH sides of the cut, then cleaned-up the cut-line w/ files, then used sand-paper to finish smoothing the edges. Here's a pic of the Majesty windscreen I 'modded' for EACH of my Gen is - LOTS of cuts...!
http://img.photobucket.com/albums/v1...y.jpg~original
and mounted.
BTW - it's available FOR SALE to fit Gen 1s. PM me....
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
