power socket - Page 4 - Kawasaki Versys Forum
 29Likes
post #61 of 76 (permalink) Old 03-12-2018, 08:33 PM
Maybe some useful info.
The Kawasaki supplied AUX circuit (activated when you plug in the relay) goes back to a 5 AMP mini blade circuit fuse. The 5 AMP circuit can handle approximately 60 watts total. I intend to use one (not two) 2.1 AMP USB plug-ins and some 20 watt "see-me" LED lights (not true DRLs). This will keep the circuit from blowing the fuse. I would not install a larger fuse because you are entering the smoke/fire realm.
Heated grips all by themselves may be dicey on this 5 AMP circuit. I would run the correct stuff supplied from the grip manufacturer. Might want to consider LED head/brake/parking lites to gain back some total wattage for the heated grips. Turn signal LEDs, imo, are a poor return on investment.
Here is a neat reference for volt/watt/amps conversion .
Voltage current resistance and electric power general basic electrical formulas mathematical calculations calculator formula for power calculating energy work equation power law watts understandimg general electrical pie chart electricity calculation
P.S. ? Anyone know what the white twin barrel (next to the aux barrel connectors) connector is for ?
2017 Versys 300 ABS, the fastest one ... green
5,000 + miles, 90% hard surface riding.
wheels2ride is offline
post #62 of 76 (permalink) Old 03-18-2018, 06:40 PM
I replaced the headlight and parking light with LEDS. Painted the white parking light yellow.
Looks good , don't know if the yellow paint will stay or melt off , lol.
Installed the relay , power socket and ran a pair of connectors for future LED see me lights.
This info may help.
I had the T-Rex engine guard and Ricochet skid plate already installed.
I did not remove the engine guard and removed all the tupperware.
W/S and front colored fascia is straight forward.
Black cowling:
Eight push pins, two black hex screws holding the silver panels on, two long silver bolts
in front center of headlight, two short silver bolts by the overflow radiator tank.
While testing the LED headlight, started the engine for a minute or two to turn on
the headlight. The brake side silver/green panel slid down and melted a bit on the
exhaust pipe ... duh.
OK, the re-install was frustrating so I removed the T-Rex engine guards.
The black cowling is tricky, start by aligning the horizontal tab, just above the headlight.
Get that right , then replace the two long silver bolts , about dead center of the headlight.
The rest you just snap, push into place. Replace the two silver short bolts bye the overflow
tank and evaporated canister. Now, align the silver/green panels and push them on.
The two long hex bolts hold the silver (side) panels to the frame.
Oh, somewhere I missed re-installing two push pins, somewhere in the middle of the black
cowling. Didn't take everything off to find out where. If I have a bad enough rattle I'll probably
do a re-do sometime in the future.
Parts diagram from Kawasaki
https://www.kawasaki.com/Parts/Parts...2017/KLE300CHF
Download the parts diagrams to a PDF, they are truncated online.
The two extra/missed push pins are near the turn signals upper black plastic to front cowling..
Part numbers 92039
If I have to get to the wiring, imo, I can do it without taking off the engine guards. Had it in pieces for a while awaiting electrical parts and forgot (age?) some of the tricky stuff.
post #63 of 76 (permalink) Old 03-18-2018, 08:07 PM
Brockie's Avatar
I have the same two push pins spare as well. And two thin screws. I'll be more careful next time. No rattles.
Brockie is offline
post #64 of 76 (permalink) Old 04-13-2018, 07:52 PM
I want to install a Powerlet plug somewhere near or in the dash, but not necessarily in the stock hole. In fact, If I could mount it in an alternate location I could install a stock style plug in addition to my Powerlet plug. This is what I had in mind.
Powerlet Socket Kit - 36" Harness - Powerlet Products
Is 36" long enough to go from the dash to the battery? I want to direct wire it so I can use it as a charging port.
SECoda likes this.
jspringator is offline
post #65 of 76 (permalink) Old 04-13-2018, 09:42 PM
Just watch the total amps limit if you are using the power in the front.
SECoda is offline
post #66 of 76 (permalink) Old 04-19-2018, 01:53 PM
Originally Posted by SECoda View Post
Any chance I could get a set of those at full resolution. 🙂
[email protected]
Anyone get service manual file? I would greatly appreciate a copy. [email protected]
fuxered is offline
post #67 of 76 (permalink) Old 05-06-2018, 11:29 AM
I got the relay plugged in. I did not remove any hardware. I can't get enough length on the pigtail to slide the relay into the retaining bar.
I don't guess that really matters. There is a retaining wiretie. I see the end but can't figure out a way to cut it.
The dashboard plug is on back order. Where do I plug that in?
post #68 of 76 (permalink) Old 08-13-2018, 12:39 PM
CheesyRider's Avatar
I'm thinking about getting this and wiring it directly to the battery:
https://www.amazon.com/Charger-CHGee...et+with+switch
Has anyone here tried this or a similar usb socket with a switch wired directly to the battery? Am I correct in thinking that since it has a fuse, there shouldn't be a problem if it shorts out for some reason?
2017 Kawasaki Versys-X 300 - 2015 Honda F6B Gold Wing
CheesyRider is offline
post #69 of 76 (permalink) Old 08-13-2018, 12:51 PM
tommyvous59's Avatar
about 8 years ago, i put in a switched auxillary fuse box in my 2008 V. really convenient when it comes to adding farkles. then, i bought a harbor freight 12v for a couple of dollars. i zip tied it to my left handlebar, and there it's been ever since. still works great. remarkably, it doesn't look bad either.
tommyvous59 is offline
post #70 of 76 (permalink) Old 08-13-2018, 12:52 PM
A problem like forgetting to turn off the switch. :-)
I have a fused power connector attached to the frame on both of my bikes for the air compressor if it has a flat direct to the battery but is is basically never used. The power outlet is under the seat to use it. You can also charge the battery from it.
I have an Eastern Beaver 8 circuit fuse box on my V-Strom 1000 but the little power output on the Versus 300 doesn't really merit that IMO.
SECoda is offline
post #71 of 76 (permalink) Old 08-14-2018, 07:48 AM
I ended up installing a plain old $6.99 12v socket that I remembered I already have. I originally purchased it to put on a scooter, but discovered there wasn't enough space to mount it where I had planned. For now, I wired it directly to the battery with a fuse. But, I plan to add the relay this fall. The Kawasaki relay is only $13.46 at Rocky Mountain ATV/MC, but to get free shipping I'll need to spend $75. So I'll get it when I buy oil and filters for the motorcycles in my household this fall.
By the time I get the bullet connectors, the total cost will be less than $25.
edit: I forgot to mention that I needed to use a Dremel to make the hole slightly bigger so the socket would fit. Did I miss others doing the same in this thread, or was the socket I used larger in diameter than most?
edit #2: I already discovered a problem with the socket I installed. The inner diameter is larger than it should be. So, when I plug in a usb adapter, the fit is not snug. I needed to wrap electrical tape around the adapter for make it fit properly. This fall when I install the relay, I'm going to replace the socket with one that has a usb port so I will not need an adapter.
Last edited by CheesyRider; 08-14-2018 at 08:55 AM. Reason: Don't buy the socket I used!
post #72 of 76 (permalink) Old 08-14-2018, 02:33 PM
Originally Posted by CheesyRider View Post
I'm thinking about getting this and wiring it directly to the battery...Has anyone here tried this or a similar usb socket with a switch wired directly to the battery? Am I correct in thinking that since it has a fuse, there shouldn't be a problem if it shorts out for some reason?
I ALWAYS run stuff so that they are ONLY powered w/ the ignition ON, so I don't find myself stranded w/ a dead battery....
Brockie likes this.
post #73 of 76 (permalink) Old 08-15-2018, 01:08 AM
Brockie's Avatar
+1. Always power accessories through a switched source, otherwise one day you will find yourself with a flat battery.
Brockie is offline
post #74 of 76 (permalink) Old 08-15-2018, 02:42 AM
Brockie's Avatar
I think that I have the very same socket as you. It's great in that you can give the plug a slight clockwise twist to lock it into the socket. I used a rat tail file to open the hole just a little. Plus see below.
Why not fit a USB plug on the opposite side of the dash as I have? Then you have future proofed any new purchases.
This image of my instruments is a bit dark but I have the cigarette lighter socket on the left and have put a dual USB with voltmeter on the right. One of these: https://www.ebay.com/p/12v-Dual-Port....c100005.m1851
The fit was easy.
Brockie is offline
post #75 of 76 (permalink) Old 10-12-2018, 04:26 PM
New How To / X300 Thread
As promised, now that it is in How To, unstuck thread, active thread link at last post of How To https://www.kawasakiversys.com/forum...lug-style.html
post #76 of 76 (permalink) Old 02-25-2019, 09:41 AM
Originally Posted by danwray View Post
FYI, if you don't want to waste the money on the OEM relay, I found one on amazon that works. It doesnt have the rubber extension that comes down around the connector, but I don't see the lack of that being an issue for me.
http://a.co/bao0plK
I used it to connect a set of heated grips to the bullet connectors, as I already have a USB charger for a set of battery tender leads.
Thanks, used this relay to get my charger set up this weekend.
golftdibrad is offline
