Versys-X 300 coolant level - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By zebraranger
post #1 of 10 (permalink) Old 08-03-2017, 12:21 PM Thread Starter
A riding friend and I have new 300s. Both our coolant levels - checked and verified via our owners manuals - are extremely low or showing empty tanks. Both bikes run cool but we're wondering about our coolant levels. Ideas, anyone?
Olcec is offline
post #2 of 10 (permalink) Old 08-03-2017, 01:30 PM
fill to just below the high mark and ride on, check it after some time and if its low again look for leaks, im betting just wasnt topped off from the dealership
post #3 of 10 (permalink) Old 11-08-2017, 10:02 AM
If you overfill the overflow tank expect some blowout on the over flow tube behind the engine.
SECoda is offline
post #4 of 10 (permalink) Old 11-08-2017, 07:09 PM
Brockie's Avatar
Mine was just below the "full" mark on delivery and has never moved. Be careful though as my mixture is a very light blue and the level is difficult to see through that fairing slit.
Brockie is offline
post #5 of 10 (permalink) Old 11-08-2017, 07:46 PM
Spud's Avatar
The dealer also properly filled the coolant reservoir just below the "full" mark for my motorcycle.
Spud is offline
post #6 of 10 (permalink) Old 11-09-2017, 11:25 AM
On my 650s there are lines for HI and LO on the side AWAY from where you can view (looking thru the fairing), so I took a black marker and put lines onto the inside where I can see them.
post #7 of 10 (permalink) Old 11-09-2017, 11:27 AM
Your nearly better off looking from the top and judging it. Much easier to see the level.
SECoda is offline
post #8 of 10 (permalink) Old 11-09-2017, 10:24 PM
Brockie's Avatar
A-ha - the tried and true stick method.
Brockie is offline
post #9 of 10 (permalink) Old 11-09-2017, 10:36 PM
Spud's Avatar
You can easily view the coolant level through the hole in the right fairing. Marking the two lines on the coolant reservoir with a black permanent marker will definitely make the job even easier.
Spud is offline
post #10 of 10 (permalink) Old 03-13-2020, 06:24 PM
zebraranger's Avatar
I just did a coolant change on the 300 and wanted to chime in on using the opening in the right side panel to view the coolant level. Depending on the color of the coolant, It can definitely be hard to see the fluid level. Over the last couple of years, I've been using a pen light flashlight pressed up against the fluid reservoir from the opening on the right side, it lights it up like a Christmas tree and you can easily see the fluid level when you press a pen light against the coolant reservoir.
Brockie likes this.
Moto Guzzi Griso 1200, Kawasaki Versys X-300
Harley Super Glide Custom, Honda Metropolitan
zebraranger is offline
