Ok....What's the trick to removing the front sprocket nut?
1 reading
45K views 24 replies 13 participants last post by  Murquiza
#1 ·
Tried a rag in between the chain/front sprocket, tried a piece of wood between the swingarm and wheel.....no luck. I'm not weak, but......???? Is it just a matter of man-handling it or what? I'm assuming it's not a reverse nut...?? Lefty-Lucy?
#2 ·
Did you?????? Open "cup washer" flange to allow for Sprocket Nut removal. Notice cup washer is facing out and replace the same way.
#6 · (Edited)
Haha. Yeah, it's a common complaint around here. It is stuck on pretty good, but I had no problems with a padded wood in wheel/swingarm and a 2-foot 1/2" drive breaker bar with 1-1/16" (26.9875mm) 6-point socket... Being a 6'1" 210 lbs ex-arm wrestling champion helps as well.
Is it 1/2" drive? If so, you could add a pipe extender on your breaker bar.
No, it's not a reverse threaded nut.
#15 ·
+1, except I used my battery powered impact. I was terrified to install a new chain and sprockets on my bike when I needed them, because of everything I read on here. I had out several breaker bars, and wood pieces. Just for fun I grabbed my impact, and it popped off.
It was the original sprocket, based on the mileage when I bought it, so it should have been on tight.
#16 ·
Borrowed an old, heavy duty air impact gun from a friend....No luck. Again, all I have is this little Crafstman air compressor, but it should easily be able to get this thing off, no? I thought maybe the washer was stopping me, so I pounded it totally flat all the way around. I'll try the long socket through to block any slack, but I'm not understanding WHERE excatly you're placing it..."between the bottom teeth of the front sprocket and the swingarm"???
#20 ·
I just bought a 16t sprocket for my Versys and remember trying to get the one off my KLR when I put a 16t on it. I tried a 24" 1/2" breaker bar with a 4 FOOT pipe. All we did was crank the bike around the garage about 3 time. I ended up at a local tire shop and they hit it with a 1/2" impact gun and even then it took four tries. Manual said 72fp on the KLR...I think they had it at 72 foot TONS!
I have a bud who has a big impact gun and I'm waiting to do the job next week end remembering what fun the KLR was.
I have never understood why it needs to be so tight anyway. The splines are what keeps it from twisting and the nut just keep the sprocket from falling off it seems to me.
#21 ·
FRIGGIN' A.....Had a buddy come over with a 3' breaker bar. I stood on the back brake with all my weight on the far side, with the block of wood blocking the wheel from spinning and we finally got it off. You guys were right about thinking you broke your breaker bars. First thing out of his mouth was "oh ****, I think I just broke my bar or your axle!".....It was just the nut, which thin spun off freely. Thanks for the help.
#23 ·
I am glad you got the nut off. I can say that my relatively inexpensive harbor freight compressor and impact wrench had the nut off with minimal trouble.
It appears that once you have the nut off and appropriately lubricate it upon replacement that it should not be that big an issue the next time.
#24 ·
It does tend to be bonded on from when originally installed dry on the seating surface. Applying lube to the threads and seating surface can result in an overtightened nut.
Repair manual does mention to: "Apply molybdenum disulfide oil solution to the threads of the output shaft and seating surface of the engine sprocket nut... Tighten to 92 ft-lbs."
I torqued it back on dry at 92 ft lbs, and it loosened normally when I removed nut a year later to replace the chain.
#25 ·
I reached this thread looking for the "secret" of removing the front sprocket and you guys freaked me out.
As the rest of you, I got ready to replace it and I couldn't remove it with anything, the air impact wrench did nothing, the breaker bar was lifting the bike and not loosening the nut. I was losing hope and thought about tensioning the chain removing all the slack, that did the trick. With a tensioned chain and the impact wrench and the tight chain, the nut came off very easily.
As a curiosity, my old front sprocket had no signs of the factory rubber dampener. It has disintegrated. The picture shows the old (17K miles vs the new one)
http://www.kawasakiversys.com/forums/attachment.php?attachmentid=120410&thumb=1
