Ram mount options - Kawasaki Versys Forum
Like Tree3Likes
  • 1 Post By weljo2001
post #1 of 11 (permalink) Old 01-25-2020, 03:37 PM Thread Starter
Ram mount options
Ram mounts, on my C14, I had 2 mounts that were on the mounting bolts of both the front brake and clutch levers using the bolts that clamp onto the bars.
Is this a favoured way for mounting on the Versys or is there enough room to clamp directly on the bar space wise?
I don't get my 2020 until spring but want to collect the accessories now while I try to wait patiently!!
rather-ride is offline
post #2 of 11 (permalink) Old 01-25-2020, 03:42 PM
52Degrees's Avatar
I bought a mirror mount RAM I haven't installed yet. Currently using a handlebar mount. I believe someone here has a ball mounted through one of the holes on the windshield bracket.
Personally, I'm not at all fond of the look of mounts on fluid reservoirs.
2016 KLZ1000GBFAL
No mods yet
52Degrees is offline
post #3 of 11 (permalink) Old 01-25-2020, 04:47 PM
On my 2016 i have this.....https://www.amazon.com/Mount-Motorcy...992216&sr=8-46 It replaces one of the riser bolts......
P1010716 by weljo2001, on Flickr
On the left side i have this mount for my cup holder......https://www.amazon.com/RAM-Zinc-Coat...9992350&sr=8-4
P1020089 by weljo2001, on Flickr
P1010714 by weljo2001, on Flickr
52Degrees likes this.
post #4 of 11 (permalink) Old 01-25-2020, 08:47 PM Thread Starter
the bars are 7/8"?
post #5 of 11 (permalink) Old 01-26-2020, 07:49 AM
FWIW I also have the one that goes in place of one of the riser bolts, had it for years and works perfectly.
One of these:
https://sw-motech.com/en/bike/KAWASA...2572053669.htm
The second photo shows how the ball mount is screwed in via a lengthened riser bolt.
If the riser bar on the 1000 is like the one on the 650, there's no room to use the handlebar clamp between the risers.
2015 Versys 650
_Big_Mac_ is offline
post #6 of 11 (permalink) Old 01-26-2020, 10:09 AM Thread Starter
I have found this,ram-b-408-75-1u no good with the picture thing, just a bit cleaner looking. for each side of the bars?
post #7 of 11 (permalink) Old 01-26-2020, 01:02 PM
the bars are 7/8"?
On the V650 - YES!
post #8 of 11 (permalink) Old 01-26-2020, 01:23 PM
Did that on my 650 for a camera mount.....
IMG_1502 by weljo2001, on Flickr
post #9 of 11 (permalink) Old 01-26-2020, 01:24 PM
On the V650 - YES!
The 1000 also....
post #10 of 11 (permalink) Old 01-26-2020, 01:39 PM
52Degrees's Avatar
That Era Versys was a good looking bike.
From the side
I thought someone here had used one of the holes on the inside that are left open in the bracket. I kinda thought it was you, actually.
2016 KLZ1000GBFAL
No mods yet
post #11 of 11 (permalink) Old 01-26-2020, 03:03 PM
From the side
I've tried rams mounts all over my 650....
IMG_0178 by weljo2001, on Flickr
IMG_0175 by weljo2001, on Flickr
