Michelin Road 5 and I'm a cheapskate - Kawasaki Versys Forum
 9Likes
  • 2 Post By Fastoman
  • 1 Post By onewizard
  • 1 Post By quexpress
  • 1 Post By jaaklucas
  • 1 Post By weljo2001
  • 1 Post By Buffalo_Bob
  • 2 Post By 52Degrees
post #1 of 10 (permalink) Old 12-05-2018, 09:32 PM Thread Starter
52Degrees's Avatar
Picked up a Road 5 rear from Chaparral on ebay last week. Amazon delivered a shiny set of spoons to my door a few days later...
Here's the problem: I have about 5600 miles on the original Battlax, and (chicken strips not withstanding) 5/16 remaining to the top of the wear bar.
Do I switch rears tomorrow or wait a while longer? What kind of mileage are others getting on their OE Battlaxes?
Also, any other California V1k riders seeing their fuel economy drop into the 36mpg range?
2016 KLZ1000GBFAL
No mods yet
52Degrees is offline
post #2 of 10 (permalink) Old 12-05-2018, 11:46 PM
MY Battlax last about 20k KM , but our road are completely different form yours and the weather too.
One way to be sure on the rear tire strength is to release all pressure and finger depress the center part of the tire. You will see how thin or hard the tire is and then you can decide weather to replace or not.
onewizard and 52Degrees like this.
Fastoman is online now
post #3 of 10 (permalink) Old 12-06-2018, 07:29 AM Thread Starter
52Degrees's Avatar
It's interesting that you say that... I never understood that differences in road construction could affect tire wear until I had been driving trucks for a while. It turns out some companies have found certain tread patterns wear better in California than in the rest of the 48, so there's likely something to that in this case as well.
2016 KLZ1000GBFAL
No mods yet
post #4 of 10 (permalink) Old 12-06-2018, 07:58 AM
As a serviceman I did the electrical for several asphalt plants, when I put my driveway in, I specified what I wanted, as my service truck was 9600 LB.s
So I first put down stone dust over a gravel base and compacted it for a month. I then had 3 inches of HL5 and 1 inch of HL3A on top, after 32 years I have two stress cracks from frost, in hindsight I should have used HL8 for the base. Yes I know way off topic here
http://www.addaline.ca/2013/asphalt-terminology/
This may come as a surprise and it largely depends on the climate that the road is exposed to. In Canada for a time studded tires were used, this is still the case in Quebec as far as I know. So some asphalt has crushed glass in it, crushed granite, numerous other things that make the road tougher but causes greater tire wear. Anyone traveling in Ontario Canada, you will find sections of Test strips where the ministry is trying different mixes in real world applications, some are for flexibility, as cracking allows water penetration then frost and then more cracking, eventual road failure.
52Degrees likes this.
post #5 of 10 (permalink) Old 12-06-2018, 12:54 PM
quexpress's Avatar
Red face 14816 km (9206 miles)
Rear BT023 down to the wear bars
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #6 of 10 (permalink) Old 12-06-2018, 02:10 PM
jaaklucas's Avatar
Anyone who has biked to Alaska via the Alaska highway has the same story,bring a spare rear tire or two. Road pavement varies all over,its basically tar sands goo mixed with the locally sourced crushed stone or whatever they have in the area. Too expensive to import nice,rounded crushed rock so they use other local stuff for strength and that can have sharper edges when crushed.Here they do a cheaper alternative sometimes on lesser roads called chip-seal, stone sprinkled on a diluted sprayed on tar over a graded gravel and rolled.Works ok, better traction for black-icy, frost-heaving roads that are in the tall shadows of big mountains. Maybe tough on the tires though. In the Baja,they dont have any local stone,lots of sand though. That along with having no local gravel for the road bed is probably why their paved roads dont hold up very well.
jaaklucas is offline
post #7 of 10 (permalink) Old 12-06-2018, 02:34 PM
I replaced the OEM tires on my V-1000 at about 7700 miles with Road 5's could have gone more but wanted to get the Michelins on. Found the best price for them at that time at https://www.motomummy.com Gas mileage always drops when they bring out the winter blend here in Cali. Seems your getting better mileage than me....
5's by weljo2001, on Flickr
post #8 of 10 (permalink) Old 12-06-2018, 03:59 PM Thread Starter
52Degrees's Avatar
That's good to know. I knew winter blend had a lot to do with it, but it seemed a bit extreme. I notice the mileage drops with the temperature, too.
Oh yeah... I got hit while lanesplitting the other day. Lol.
2016 KLZ1000GBFAL
No mods yet
post #9 of 10 (permalink) Old 12-06-2018, 07:01 PM
Wow, are you OK? Details?
Buffalo_Bob is offline
post #10 of 10 (permalink) Old 12-06-2018, 09:11 PM Thread Starter
52Degrees's Avatar
I'm fine. Got squeezed between a Camry and a big rig. Felt a bump that could have been a reflector on the road and went about my commute. Found scratches on the left pannier and dirt or green Camry paint it something in the dot lettering on the reflector.
Evidently, it's not a hit and run if you didn't know you were hit until later.
weljo2001 and Buffalo_Bob like this.
2016 KLZ1000GBFAL
No mods yet
