What the hell is that? - Kawasaki Versys Forum
 5Likes
  • 5 Post By Steve in Sunny Fl
post #1 of 14 (permalink) Old 09-17-2018, 09:37 AM Thread Starter
So last week I had the bike at the dealership as I had the dreaded water pump oil weeping issue (also strangely my bike had a bent front rotor as well). Anyway, I got the bike back and I noticed down by the water pump there is now a small plastic bottle tied to the end of a rubber hose that disappears up into the rats nest of hoses on the gear shift side of the bike. There is nothing in this bottle but now Im going nuts wondering if this is something new or if Ive just never noticed it before or if its been there but was rerouted by the dealer while they were working on it.
Google search came up with nothing and if nobody has an answer here I will start digging through the parts books to see if I can find it.
DrGonzo615 is offline
post #2 of 14 (permalink) Old 09-17-2018, 10:09 AM
That's attached to the air box, used to catch oil?
Sound like what you are talking about.
Edit to say now that I think about it my drain tube on the air box is just a tube with a bolt in the end of it maybe? No bottle? Been a while since I took it out. But yours is a 1k mine is an older 650.
Kyle E is offline
post #3 of 14 (permalink) Old 09-17-2018, 12:03 PM
Take a photo and post it!
post #4 of 14 (permalink) Old 09-17-2018, 01:05 PM Thread Starter
Updated the original post.
post #5 of 14 (permalink) Old 09-17-2018, 01:34 PM
Yep drain hose for oil in the air box.
https://www.partsfish.com/oemparts/a...a0/air-cleaner
Kyle E is offline
post #6 of 14 (permalink) Old 09-17-2018, 01:54 PM Thread Starter
Gotcha, is it normally routed this way? I dunno how I never noticed this before.
post #7 of 14 (permalink) Old 09-17-2018, 03:48 PM
Don't have the 1k, but on the 650 its just mixed in with the wiring like in your photo. Its probably someplace else from the factory and the dealership just routed it different. I wouldn't worry about it. Maybe tuck it up a little higher or something.
Kyle E is offline
post #8 of 14 (permalink) Old 09-17-2018, 07:14 PM
ToSlow's Avatar
what yr is your 1000
Living Large
ToSlow is offline
post #9 of 14 (permalink) Old 09-18-2018, 10:03 AM Thread Starter
2016
post #10 of 14 (permalink) Old 10-11-2018, 08:41 AM
How common is the water pump oil weeping issue? When does it usually show itself and is repaired under a recall or is it just a design flaw?
Kawiflyer is offline
post #11 of 14 (permalink) Old 10-11-2018, 10:54 PM
mrvwbug's Avatar
That it has that big of an airbox oil drain is an ominous thought. The 650 has just a length of hose with a cap on one end and after about 20k miles mine only had a small amount of oil in it, I drained it when I pulled the airbox off to do the spark plugs.
mrvwbug is offline
post #12 of 14 (permalink) Old 10-12-2018, 09:33 AM Thread Starter
Not sure, but it seems fairly common. I noticed a few little droplets in the plastic guard beneath the water pump. It definitely wasnt a serious leak but it seemed to be leaking both coolant and oil that was weaping from where the pump mates to the case. The dealership I took it to didnt mention anything about a recall and covered it under warranty. Ive probably done roughly 500 miles or so since it was replaced and knock on wood, it seems to have fixed the issue.
Yeah seems a bit weird but I have about 3k miles on my bike and I dont see a single drop of anything in it.
post #13 of 14 (permalink) Old 10-13-2018, 05:28 PM
Don't know if it's the same, but mostly kaws use the same kind of stuff. Here's a video I dod on water pumps for the zg1000 a couple years back
Steve
Steve in Sunny Fl is offline
post #14 of 14 (permalink) Old 03-18-2019, 11:00 AM
nicely done steve; excellent video and well explained!
jim
funflyingguy is offline
