Purchased A Throttle Lock Today :grin2: - Kawasaki Versys Forum
 8Likes
post #1 of 24 (permalink) Old 07-13-2018, 05:40 PM Thread Starter
https://www.amazon.com/8M4991-Caterp...J45WHTMVNKZR89
post #2 of 24 (permalink) Old 07-13-2018, 06:01 PM
StormRider's Avatar
Haha...looks state of the art. I love when simple things can be repurposed for complex tasks.
weljo2001 likes this.
_______________________________________________
2015 Kawasaki Versys 650 - Barkbuster hand guards, Hepko & Becker crash bars, Oxford Heated sports grips, Motowerk lowering Kit with Kickstand insert, Shad SH45 Top Case and Brake Light, Shad Versys Top Mount Kit, Superlite 43T Rear Sprocket, National Cycle VStream Sport Touring Windscreen.
Roaming the country around Columbus in ever wider circles.
StormRider is offline
post #3 of 24 (permalink) Old 07-14-2018, 03:57 PM Thread Starter
Just got back from lunch and looking at my grips the O-Ring i ordered might not work with the Koso Heated Grips i have....
post #4 of 24 (permalink) Old 07-14-2018, 08:19 PM
tommyvous59's Avatar
as long as it doesn't impede you from rolling off the throttle in a pinch ....
tommyvous59 is offline
post #5 of 24 (permalink) Old 07-14-2018, 10:23 PM Thread Starter
Not much room to put it with the Koso's...
P1010703 by weljo2001, on Flickr
P1020088 by weljo2001, on Flickr
post #6 of 24 (permalink) Old 07-15-2018, 06:32 PM
Joe - at least you're not out too many $....
post #7 of 24 (permalink) Old 07-15-2018, 08:13 PM Thread Starter
Thats true. I'll put it on the boys GSXR-750....
post #8 of 24 (permalink) Old 07-15-2018, 09:17 PM
Can't you slide the grip closer to the switch housing?
Looks like it would create a gap between grip and bar end to insert the o-ring...
Another option would be so shim the bar end with one (or two) washer(s) to create the needed gap.
Claude. is offline
post #9 of 24 (permalink) Old 07-15-2018, 09:31 PM
ToSlow's Avatar
i work on a lot of cat equipment, probably got 20 to 30 of those o-rings in my work truck
ToSlow is offline
post #10 of 24 (permalink) Old 07-15-2018, 09:50 PM
10 for $5.62 best price I've found. https://www.ebay.com/itm/10-Aftermar...A0.H1.X8m.TRS1
Skypilot 69 is offline
post #11 of 24 (permalink) Old 07-16-2018, 10:38 AM
Best bang for the $$$$
For simplicity of mounting and function, you can't beat this , also I have the cramp buster, this is with Oxford heated grips. FYI I had the plastic version of Go Cruise, it decided to blow off on a very hot day, while parked, I took the peices into Twisted throttle and upgraded to the aluminum one, well worth the extra $20, as it is adjustable as to tension.
Stuck a plastic bottle between the brake, notice this is a simple move it forward while at speed then crank throttle forward to release.
post #12 of 24 (permalink) Old 07-16-2018, 10:44 AM
[r
Have a look at my Go Cruise aluminum lock, less than 1/2 inch required, uses the brake lever , move forward at throttle with thumb, roll forward on throttle to release.The area it travels on comes with the kit , something like a silicone wide rubber band. You need to take the bar weight off to get it on.
http://www.twistedthrottle.ca/go-cru...-auminum-black
post #13 of 24 (permalink) Old 07-16-2018, 11:07 AM Thread Starter
Go Cruise 2 Throttle Device Universal, Aluminum | Black - TwistedThrottle.ca
I have one of the Original Go-Cruise sitting on my desk. Bought it for the 09 V.......
post #14 of 24 (permalink) Old 07-16-2018, 01:21 PM
...also I have the cramp buster,
After having TWO friends crash their bikes due to a "Cramp-Buster" problem, I recommend people to NOT use them!
First happened in Alaska (Suzuki Bandit 1200S) when my friend turned UP a steep driveway, which turned out to be the WRONG one. He tried to do a U-turn to the right and his hand caught the Cramp-Buster, jamming the throttle ON, and he went down w/ his 500# Suzuki pinning him. He was pinned for around 10 minutes before somebody saw it, and helped get the bike off him.
Second happened in AZ, my friend (relatively inexperienced on dirt) leading on his '09 Versys riding down a dirt road a "BIT" fast, when he got into the soft stuff on the left shoulder. His bike started into a "tank-slapper", he couldn't get the heel of his right-hand off the Cramp-Buster so the throttle was pinned WFO. He hit a large rock and flew over the handlebars, landing on his back. I ran over to help him (NOT seriously hurt!), checked his bike (broken engine-case), then he rode out pillion w/ me about 14 miles to where we could get cell reception to call a tow-truck.
FIRST thing he did after we got his bike up, was remove that Cramp-Buster and THROW it as far he could, into the desert!
Skypilot 69 likes this.
post #15 of 24 (permalink) Old 07-18-2018, 04:00 PM Thread Starter
Got my Yellow O-Ring in today will test it out tomorrow......
Groanup likes this.
post #16 of 24 (permalink) Old 07-18-2018, 06:22 PM
crosshairs's Avatar
Hurry up , cause if it works I want to order one and get it by the weekend...
2016 green V1K
crosshairs is offline
post #17 of 24 (permalink) Old 07-18-2018, 06:24 PM
If you notice the angle it is at, I typically rotate it forward, completely around, once in the city, what you see in the picture is too low for any help.On the highway I rotate up once into a long stretch of highway If I was on dirt it wouldn't be on the bike, since I don't do dirt, don't have knobies and I sold my DRZ400S for the very reason that I was getting too old driving the rutted 4X4 tracks in my area , as I got pinned twice in 1 year, one was due to someone putting plywood under a 4X4 to get it out ( on a curve), leaving it in place covered by mud. Too many highway paved road miles causing cupping on the tires.I bought a 07 now a 15 Versys.
I will keep that in mind though, maybe one day I will remove it.
post #18 of 24 (permalink) Old 07-18-2018, 06:25 PM
I will take the fall as the dumb, old guy. How do you turn that ring in to a throttle lock??
Thanks, Chuck
cjcintucson is offline
post #19 of 24 (permalink) Old 07-18-2018, 07:05 PM Thread Starter
Thanks, Chuck
Image 7-13-18 at 11.54 AM by weljo2001, on Flickr
post #20 of 24 (permalink) Old 07-19-2018, 06:55 AM
ACE50 is offline
