Same regulator/rectifier? - Kawasaki Versys Forum
 1Likes
  • 1 Post By invader
post #1 of 4 (permalink) Old 12-14-2016, 10:20 AM Thread Starter
BEACHBUM's Avatar
Does anyone know if the V1K has the same shunt type r/r as the 650?
BEACHBUM is offline
post #2 of 4 (permalink) Old 12-15-2016, 10:18 PM
Just Posted Under Koso Apollo Grips
Kind of asked that question with Weljo
I would think it is shunt, but would need to dig into the manual, find out what the stator is rated for maximum output.
post #3 of 4 (permalink) Old 12-22-2016, 09:34 AM
Versys 1000 Charging System-
Type Three-phase AC
Alternator Output Voltage 44.8 V or more at 4,000 rpm
Stator Coil Resistance 0.17 ∼ 0.25 Ω at 20C (68F)
Charging Voltage (Regulator/Rectifier Output Voltage) 14.4 ∼ 15.0 V
Charging Output: 413 watts max
Regulator/Rectifier Resistance (Unit: kΩ) See page 559:
http://www.kawasakiversys.com/forums...4&d=1353741364
post #4 of 4 (permalink) Old 12-22-2016, 10:28 AM
99% Sure Shunt Type
So I would say only two series regulators available the, compu-fire and the one at Roadster.com, the Polaris would work under normal driving conditions, however without cooling it has a 14 amp rating.
