Switched Over To Synthetic Oil - Page 2 - Kawasaki Versys Forum
Like Tree25Likes
post #21 of 44 (permalink) Old 03-06-2017, 09:25 AM
Originally Posted by hfjeff View Post
Rotella T6 is popular on the Yamaha FJR forums as well. Here in the midwest it is about $21/gal at Wal-Mart. Cheaper than the manufacturer oils and no issues. Shifts great. Amsoil is probably superior, but I am a cheap-skate.
At one time I was a supporter of T6 use in our V's. Until I heard from a lubrication engineer at Shell/Rotella - he said T6 is not recommended for vehicles with catalytic converters, as it could lead to eventual partial clogging of the converter, and will result in reduced engine performance. I posted the email from him somewhere on this forum.
I have recently read posts from other technical people that T6 is desirable for use in older motorcycles, that do not have cat. converters.
Dave
trialsguy is offline
post #22 of 44 (permalink) Old 03-06-2017, 04:33 PM
quexpress's Avatar
Originally Posted by trialsguy View Post
At one time, I used Rotella T6 in my '08 V. I switched to Mobil 1 for motorcycles a few years ago.
Look at the Q & A of the Rotella link above - it says that the amount of sulfur in this oil will clog "modern" catalytic converters used for gasoline engines, and that T6 its is for diesel engine use only (or gasoline engines with out a modern cat converter). [There was no explanation of what "modern" means. ?]
Since we've read it on the interweb, it must be true...
Clog is a term used incorrectly.
See: https://www.bobistheoilguy.com/forum...Number=2863902
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #23 of 44 (permalink) Old 03-06-2017, 04:48 PM
quexpress's Avatar
Dave
If you Google We do not recommend Rotella T6 for engines with catalytic converters, you'll see that this preformatted response has been sent to many people. It is most probably sitting in a database and automatically sent out as a reply.
Someone else wanted to know the reason for this response and contacted Shell a second time:
https://forum.ih8mud.com/threads/zdd...6-cats.821219/
I was thinking that it was the ZDDP/zinc in the RotellaT and T6 oils that was contaminating the cat's and MAYBE the O2's via oil consumption. I sent an email to Shell and got a reply:
Dear Sir,
If you are using oil between oil changes (consumption), then you can shorten the life of a catalytic converter which is the result of the ZDDP additive contaminating the catalyst. It is for this reason that we do not recommend using Rotella oils in gasoline engines with catalytic converters.
There is no way I am aware of to remove the contamination once it is attached to the catalyst.
Regards,
Shell Technical
So ... unless my Versys starts burning oil, I will keep using Rotella T6 in my bike (as I have done with my previous ones).
Note: ZDDP contains zinc which is an anti-wear additive. It also contains phosphorus which is helpful for preventing gear wear.
Like any oil thread, there are always numerous opinions. This is mine!
post #24 of 44 (permalink) Old 03-06-2017, 06:16 PM
Where were You This AM?
Dear Sir,
Regards,
Shell Technical
I spent 20 minutes trying to find that post
quexpress likes this.
post #25 of 44 (permalink) Old 03-07-2017, 09:37 AM
Interesting info. I agree that "clog" is not the best word to use in this case. My mind sometimes drifts to the "worst case" over time.
Now, I don't feel so bad about using Rotella oils for the first 20,000 miles of my V's life. That being said, I'm sticking to name brand motorcycle specific syn oil for my V. It only costs me an extra $10 per year, for the cheap insurance.
post #26 of 44 (permalink) Old 03-07-2017, 09:52 AM
<snip> But we got him a BMW 535d and all his maintenance is included so I've already stocked up on Motul 7100 Synthetic for the bike for a year or so.
So, ah, wanna adopt me?
I've got my eye on the new Maclaren and I'm sure they're only gonna throw in one or two oil changes on the car sale, so I need a Grease Daddy to keep me in petroleum products. and insurance. and lawyers for the tickets. and supply sticks to keep the beach bunnies at bay...
onewizard and weljo2001 like this.
aboyandhisversys is offline
post #27 of 44 (permalink) Old 03-07-2017, 01:00 PM
I just had this "argument" with a friend the other day who decided he was gonna "fool the system" and use Rotella. Even dumber, he's in a...02? 250 Ninja...whatever the last year was that they used carbs...and he's like the third owner of this little wrung out, beat to crap pocket rocket.
He was like "Buh buh buh it's so cheap!"
I'm like...dude, my V uses 3 quarts of oil at a time. If I buy Mobil 1 Racing 4T at Wal-Mart, it's $9 a quart. $27 for the piece of mind to know absolutely that I've got an oil that hits all the specs that I want it to, that was specifically designed to be used in a wet-clutch motorcycle application.
And he was like "Yeah but the 4T is only $23, for a WHOLE GALLON!"
And I'm like...a whole gallon nets me 1qt short of two changes, and then I'm sitting on a half-full tub of oil that I've gotta protect and make space for, and I can't use it to store/recycle the old oil, and I've still gotta buy another quart @ $8. $32 for 2 oil changes w/ Rotella, $52 for two with 4T. Sure, that's $20. $20 across 6,000-10,000 miles. $20 to peace of mind. I spend $20 on lunch half the time, so it's obvious for me.
That said, I am switching to Amsoil 10w-40 "Metric Motorcycle" this spring. Not cheap, but again---I want this bike to last, as great as possible, for as long as possible.
AdventureSeeker is offline
post #28 of 44 (permalink) Old 03-07-2017, 08:18 PM
hfjeff's Avatar
Did I say Rotella T6? My bad - I meant to say that I also use Amsoil Synthetic 10w-40 and it is an excellent choice. (Sorry Weljo for starting the oil war that you did not want to start).
Those magnetic plugs are one of the best simple inventions. It holds the fine metal dust and allows you to actually remove it from the engine rather than just holding it out of the way.
weljo2001 likes this.
2011 Yamaha FJR 1300
hfjeff is offline
post #29 of 44 (permalink) Old 05-05-2017, 06:28 PM
Husky44's Avatar
I bought three gallons off Amazon.. Seems like a fair price and decent oil
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
invader likes this.
2016 Versys 1000LT Roseville, CA
Husky44 is offline
post #30 of 44 (permalink) Old 05-05-2017, 07:08 PM
$66.84 ($5.57 per quart) plus shipping for 3 US gallons?
post #31 of 44 (permalink) Old 05-05-2017, 08:01 PM
Husky44's Avatar
Mine shipped free (over $35).. I was in no hurry so standard shipping was fine.
Factory case with 3-us gallon jugs
Arrived in less than a week.
invader likes this.
Husky44 is offline
post #32 of 44 (permalink) Old 05-05-2017, 08:33 PM
Question
Does it smell good?
post #33 of 44 (permalink) Old 05-05-2017, 08:51 PM
Husky44's Avatar
Does it smell good?
I'll find out tomorrow when I change the oil
Husky44 is offline
post #34 of 44 (permalink) Old 05-05-2017, 09:14 PM
Does it smell good?
That's what she said
Lurch71 is offline
post #35 of 44 (permalink) Old 05-05-2017, 10:20 PM Thread Starter
Does it smell good?
Did someone fart....
post #36 of 44 (permalink) Old 05-06-2017, 07:45 AM
Just putting this here for fun. Gave me some things to think about. Let's face it - if you're using short changes, anything will likely work, and the shifting is the big deal. On my cruisers, I would get an 800 mile break in of the oil and the shifting would fade a little. Then level quality shifting. If I was doing mountain twisties the oil would stop shifting as smooth at about 2000 miles, if longer trips, then about 3000 miles. I got to where I'd just wait until the shift started to clunk and change. My single high-dollar synthetic experiment gave me a few hundred more miles!! That was it.
The Case for Using Mobil 1 15W-50 Automobile Oil in a Motorcycle - Ducati.ms - The Ultimate Ducati Forum
Reply from Mobil on their 15W-50 - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Interesting stuff. I imagine I'll give it a whirl in the Versys perhaps. I would run 20W 50 synthetic (real or US synthetic) without even thinking about it. I'm not concerned about engine lubrication really, it's the shifting and transmission that concern me. Modern oil and engines are good!
By way of contrast, my big bike is on Amsoil 60W, which is above the standards for the engine and available. Doesn't have to handle the clutch, but has some magic huge 3 stage catalytic system. At nearly 6000 miles on Amsoil 60W, still looks completely transparent with no sign of any degradation to the eye - good stuff in a great engine. 1400 air cooled different from Versys! I am thinking if I analyzed it I'd be good for 10,000 miles on that oil. But 6000 is about the life of a rear tire (heavy bike) so I can do everything at once.
VStrom will get the 15W-50 test next change. Clunky shifting on that one.
And I'll keep my eyes out for a suitable stainless filter for the bikes. On sale.
Dr. Toaster: Guzzi 1400 California, VStrom 1000
Mrs. Toaster: 2009 Versys 650
Located 50 miles W of Deals Gap aka Dragon
toaster404 is offline
post #37 of 44 (permalink) Old 05-06-2017, 10:17 AM Thread Starter
Amazon usually has the best prices for the PCS Filters the PCS-1 fits the Versys 650,Versys 1000 and FJR 1300's I've had the same filter since 2010 that i've used on all 3 of those bikes...https://www.amazon.com/PC-Racing-PCS...S-1+oil+filter
IMG_0122 by weljo2001, on Flickr
P1010573 by weljo2001, on Flickr
post #38 of 44 (permalink) Old 05-08-2017, 01:30 PM
Husky44's Avatar
Does it smell good?
Smells great
Very surprised with how nice it smells, may use it as after shave.
invader likes this.
Husky44 is offline
post #39 of 44 (permalink) Old 09-14-2017, 05:39 PM Thread Starter
Decided to do an oil change today. It's been 3500 miles since the last change a little early but what the heck. Used the last of my Amsoil on the last change but got a good deal on a couple 4 litre containers of Motul 7100 last year. So I've been wanting to check out how the Motul does.Got the oil change done De-greased the lower black panel while i had it off. While i was cleaning the PCS-1 oil filter i went ahead and changed the O-Ring on it. The O-Ring i replaced had been on for 2 years and the one before that was on for 5 years both still looked good when replaced. Lubed the chain and put on a new set of mirrors i want to try out.
post #40 of 44 (permalink) Old 09-15-2017, 03:20 PM Thread Starter
Took the bike out for a lunch run and to do some errands. Running nice and smooth. I like the Motul 7100 plus it has a pretty red color..
