Dealership Service Headaches - Kawasaki Versys Forum
 5Likes
  • 1 Post By twowheeladdict
  • 2 Post By fasteddiecopeman
  • 2 Post By aboyandhisversys
post #1 of 11 (permalink) Old 09-12-2017, 04:36 PM Thread Starter
Got my bike back last friday and there were a few service issues when in there but when i was told it was ready. I get there to see one of the pegs to be replaced wasn't then i open my new top case to put stuff in it and the top case lights are just laying inside. So got with the service writer who got with the tech that took the light kit out of the old case and was suppose to install in the new one. He said he wasn't getting any power and checked it. I knew they were working when i brought it in. So i'm getting a little pissed and the service writer said he can order the part from Admore to fix it. I said F- it i just want to go. So he's really trying to make it right saying they'll cover the cost and what-not. I told him it was just probably a loose wire at the harness that probably got tugged on so i would check it when i got home. Got home took off the seat and looked at the harness. Yep one wire sticking out so i fixed it and connect the wiring together to see if it worked and it did. So kinda pissed if they would have went ahead and drilled the hole i could have installed it myself. Told them i would be in today for them to finish up the job. But on friday i sent a video of how to run the wiring and the holes that would need to be drilled and sent then the link to the instructions from Admore web-site.
Hello Brian,
Hers a couple of things that will come in handy……
1.
2.https://admorelighting.com/Web%20Ins...structions.pdf
Thanks,
Joseph
Took it in today and waited for them to get it done so when the bring it to me he shows me that everything works correctly except a few of the running lights on the right blinker. So i said i would look at it when i got home. Well had to run some errands and was putting my jacket and helmet in the top case and noticed how they ran the wires....Bingo i think i found the problem.....
P1020080 by weljo2001, on Flickr
P1020081 by weljo2001, on Flickr
P1020082 by weljo2001, on Flickr
I know I'm kinda picky but this is just sloppy work. I even asked did the same guy take the light kit out of the old case and they said yes...So he knew how the new one should be done and 2 holes would have to be drilled to run the wires. Maybe he's just lazy or doesn't give a crap..
post #2 of 11 (permalink) Old 09-12-2017, 04:45 PM
james75's Avatar
That's why I do stuff like this myself. I don't trust my local dealers to do much.
james75 is offline
post #3 of 11 (permalink) Old 09-12-2017, 04:56 PM
timster's Avatar
That's why they call it the stealership!! Its hard to find a good one with a good service dept. that you can trust. I barely trust them putting on tires!
You will never see a motorcycle parked in front of a psychologist office!
timster is offline
post #4 of 11 (permalink) Old 09-12-2017, 05:12 PM
Another sterling example of Too Big to Fail...
aboyandhisversys is offline
post #5 of 11 (permalink) Old 09-12-2017, 05:15 PM Thread Starter
You guys are right. I had a fantastic dealership back in Ft.Worth,Tx. Honda/Kawasaki West the service there was amazing. Out here in California they just don't even try to be sub-par. You would think that they got almost 4 thousand bucks out of the deal with labor and parts that they would at least try to look half way professional...
post #6 of 11 (permalink) Old 09-12-2017, 07:25 PM
Typical "skilled" worker these days. They are just parts changers. If they have to figure something out, forget about it.
When I had a choice between fixing a bike or totaling it out, I told them to total it. Then I bought a used bike from an individual instead of another one from that dealership.
weljo2001 likes this.
post #7 of 11 (permalink) Old 09-13-2017, 11:41 AM
Originally Posted by timster View Post
...I barely trust them putting on tires!
I started 'doing' my own tire changes after my FIRST (done by a dealer), when they installed the tire backwards AFTER I had reminded them which rotation was the proper way.
weljo2001 and timster like this.
post #8 of 11 (permalink) Old 09-13-2017, 01:28 PM
I told idiot dealer 3 (three) x times which way to put the 90 degree tire valves so they faced uphill.
Which way did they put them on? Left/port side so now I get to fight with chain lube and panniers and all that crap which I was trying to avoid in the first place.
If 3x times isn't enough, God only knows what they'd do with something complicated.
post #9 of 11 (permalink) Old 09-13-2017, 02:34 PM Thread Starter
That reminds me that i have to have the 90 degree angled valve stems i have put on when new tires are do in about 2000 miles or so..
post #10 of 11 (permalink) Old 09-14-2017, 12:25 PM
Of course, having gone through that painful experience, I found a tire fill chuck that may result in you not having to put 90° stems on quite so soon:
https://www.amazon.com/Motion-Pro-Ch.../dp/B01CGKI3OG
I got one on sale someplace; they're expensive but boy! does it work. motorcycles, tractors (my main pain) all submitted gracefully to being filled without drama. FWIW, YMMV.
post #11 of 11 (permalink) Old 09-14-2017, 01:22 PM Thread Starter
Nice find.....I like our prices better...https://www.amazon.com/Motion-Pro-Ch.../dp/B01CGKI3OG
