15' Versys 1k Power Selection - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By twowheeladdict
post #1 of 3 (permalink) Old 01-03-2016, 05:51 PM Thread Starter
Question 15' Versys 1k Power Selection
So, my new bike has a power selection setting for 100% or 75%. Drives and shifts nicely at 75% power but I am hearing a ticking noise. Anyone else hearing such a sound on lower power?
Wingleader is offline
post #2 of 3 (permalink) Old 01-03-2016, 08:55 PM
saddlebag's Avatar
No, but I wear a helmet and earbuds playing XM, so I'm prolly the wrong person to answer.
My Victory would tick for a while after I started it if it hadn't been run for some time. I only noticed that as it made the noise before I put my helmet on. I don't generally pay little things like that much attention. It's made of metal and things expand and contract and little metallic noises are inevitable.
As to the power modes, I agree with you. In stock form, the Low Power Mode has much nicer throttle response. On/off throttle is very jerky in Full Power mode. Makes riding in the tighter stuff sloppy.
Fortunately, there is a solution. Fuel Moto sells a Power Commander with proper adjustments to make the Full Power mode's on/off throttle as nice as the Low Power mode's, but has the advantage of making even more power. You can get one here:
Fuel Moto | Dynojet - Power Commander V
saddlebag is offline
post #3 of 3 (permalink) Old 01-03-2016, 10:12 PM
Victorys have hydraulic valve lash adjusters that require pressure to operate optimally. When you let the bike sit, the pressure bleeds out so you have a little noise until pressure builds.
That has no bearing on the sounds from the Versys 1000 since it is shim under bucket. If there is a ticking on 75% power, but not with 100%, then there is something not quite right. I would research how Kawasaki implements the power modes to learn what is different.
Good luck.
saddlebag likes this.
