2nd post - How to oil chain w/o center stand? - Kawasaki Versys Forum
post #1 of 19 (permalink) Old 08-05-2015, 01:32 AM Thread Starter
Cantdrive55's Avatar
I'll be looking for advice on how to best oil the chain.
All my other bikes have had center stands, but I'm open to all good ideas.
Will be looking for recommendations on side cases soon too...
Cantdrive55 is offline
post #2 of 19 (permalink) Old 08-05-2015, 02:25 AM
I use my rear race stand to lift the back wheel off th ground.
08' Versys
HAWKSHOT99 is offline
post #3 of 19 (permalink) Old 08-05-2015, 02:50 AM
Buy your self a set of rear spools or bobbins M10x1.25 pitch bolt
and use a paddock or race stand as mentioned.
Gigitt is offline
post #4 of 19 (permalink) Old 08-05-2015, 05:05 AM
Harbor frieght./princess auto have decent pit stands cheap. Spools are very cheap on eBay. You need a pit stand and spools to do any work on the bike
post #5 of 19 (permalink) Old 08-05-2015, 05:39 AM
BLACK DOG's Avatar
race stands at home, pac-jack on the road.
BLACK DOG is online now
post #6 of 19 (permalink) Old 08-05-2015, 06:45 AM
post #7 of 19 (permalink) Old 08-05-2015, 07:34 AM
Thaylin's Avatar
I do this standing on the left side of the bike on a flat road. I put the bike in neutral, keep the kickstand down, then I grab the rear grab handle and stand the bike up straight. I then walk the bike slowly forward while spraying the chain. Yes I know the dangers of doing this, but it's quick and can be done at the gas station before a fill up if you don't want the extra weight in the gas tank.
Thaylin is offline
post #8 of 19 (permalink) Old 08-05-2015, 08:02 AM
I have a rear stand, a pac jack, and a 2X4. The board is getting a lot of use since the rear wheel stays cleaner with the bike on the side stand. Just cut a 2X4 about half inch too long to fit between axel nut floor and use it in place of the pac jack. I would use the pac jack more but it is stuffed in my luggage in the basement.
brent375hh is offline
post #9 of 19 (permalink) Old 08-05-2015, 10:32 AM
I'mwith the masses on rear stand. Or 2x4 method
You don't NEED it but it makes life alot easier
post #10 of 19 (permalink) Old 08-05-2015, 10:37 AM
BLACK DOG's Avatar
If it's a shiny tool I NEED it
post #11 of 19 (permalink) Old 08-05-2015, 11:13 AM
gotfz1's Avatar
Rear stand at home. For trips a length of 1" box aluminum that props the right side up using a swingarm spool.
gotfz1 is offline
post #12 of 19 (permalink) Old 08-05-2015, 11:15 AM
kohburn's Avatar
or use an auto oiler and never worry about it again (except the ocassional wipe down to remove any grime build up.
kohburn is offline
post #13 of 19 (permalink) Old 08-05-2015, 11:44 AM
kballowe's Avatar
At home I put it on the stand, start the bike and put it in gear and then spray as the chain goes by....... On the road, I just spray -n- roll -n- spray -n- roll.
kballowe is offline
post #14 of 19 (permalink) Old 08-05-2015, 05:10 PM
King.Versys's Avatar
King.Versys is offline
post #15 of 19 (permalink) Old 08-05-2015, 05:18 PM
I use a cut-down old crutch on the road...
and a piece of two-sided Velcro to lock the front brake...
then stick the crutch under the right-side spool...
and spray WD40 in onto the inside-lower run, turn the wheel a bit, spray, etc, till it's all wet. Then spin the rear wheel three times w/ my foot, then wipe excess off the chain; lift bike a bit to remove the crutch-stand AND then the Velcro OFF the front lever. DONE!
At home - a rear stand, and ALWAYS done on a hot chain when I return from a ride.
post #16 of 19 (permalink) Old 08-05-2015, 06:02 PM
gotfz1's Avatar
Please take video
gotfz1 is offline
post #17 of 19 (permalink) Old 08-05-2015, 06:55 PM
Originally Posted by gotfz1 View Post
Please take video
That's not a normal way to wax the chain?
Why would I manually move the wheel when I payed for a motor? I could have had your vid if you requested last night.
Just make sure you put some cardboard on the ground to collect the fling.
08' Versys
post #18 of 19 (permalink) Old 08-05-2015, 11:08 PM Thread Starter
Great ideas to work with. I'm curious about the auto-oiler idea too. I'll look into that.
Thanks!
post #19 of 19 (permalink) Old 08-05-2015, 11:09 PM Thread Starter
Excellent pics and explanations! Thanks!
Closed Thread
