Friends Versys led turn signal problems - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 05-08-2015, 10:55 PM Thread Starter
So a buddy got some LED turn signal mirrors for his bike.
I put LED strips in my headlights that are tied to my turn signals in series, they flash just fine and both run. but the previous owner but my flush mount signals in and now im not sure if they are LED or bulb.
because i tried to put the versys LED mirrors in series with their turn signal and i have 2 problems. The LEDs blink twice speed, and the regular turn signal bulb never lights up.
Is it possible to wire the LED mirror in series with the front left turn signal bulb and have them both run? Is there a reason why the bulb is not running and the LEDs are? If both are in series then they should get the same current, and there isn't that much of a voltage drop for the bulbs....
Any ideas? friend wants lights working tomorrow which means NAPA parts and elbow grease.
caedo is offline
post #2 of 3 (permalink) Old 05-09-2015, 03:03 AM
You wired it wrong. connect parallel to original bulb turn signal.
The LED uses less current and the relay cannot blink correctly. Sounds like LED is connected and original Turn bulb is disconnected.
Blinker: + positive wire, E earth wire
---E
Blinker and LED
---E---E
Series is:
---+---E---+---E
Gigitt is offline
post #3 of 3 (permalink) Old 05-10-2015, 05:02 PM
I know NOTHING about electrics, but when I put the LED lights on my aluminum panniers, I just 'added' them to the wires for my stock rear sigs (parallel...?), and everything flashes normally, as the stock resistance is still there w/ the stock bulbs.
