2008 Versys KLE ABs - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 12-06-2014, 06:30 AM Thread Starter
2008 Versys KLE ABs
I have a 2008 KLE ABS with 44000 miles. The bike starts on the button and the automatic choke kicks in for about 3-4 minutes. As soon as the choke turns off the revs drop and the bike stalls. When I restart it it either runs ok or takes a couple of attempts and then runs ok. Very occasionally the revs will drop when filtering through traffic at low speed but when this happens the bike starts ok. Apart from this problem the bike runs just fine, no smoke, doesn't use any oil and pulls through all the gears like it always has done. Does anyone have any clue as to what might be the cause of this problem? Where and what do I start checking? Obviously I want to avoid hefty garage charges as hopefully it will be something that I can identify and fix myself.
Many thanks
Nick
jacko141 is offline
post #2 of 7 (permalink) Old 12-06-2014, 12:15 PM
Mac-man's Avatar
I had a similar issue when I was trying to nail down my idle speed and made it a bit too lean. When the choke kicked off the bike would stall.
There is an idle adjustment screw which is on (I believe) the right side of the bike.
I stole this picture off the internet but it's a kawasaki and the screw looks very similar. It has a large flared head so it can be adjusted by hand.
It's a little below of dead center in this picture.
I would tighten that in a little before you pay someone to try the same
Luck favors the prepared.
Mac-man is offline
post #3 of 7 (permalink) Old 12-06-2014, 12:51 PM
what mac said , turn your idle screw in 1/4-1/2 turn and see if it says running , if it dosnt repeat till it does, once it does turn the screw out till your idle is at 1,300(-,+50)rpm and see if it will start up and stay running then,
another thing to check would be your spark plugs they could be slightly fouled
post #4 of 7 (permalink) Old 12-06-2014, 03:56 PM
I think you mean (-, +50)rpm; not (-.+500)
ScottyNeal is offline
post #5 of 7 (permalink) Old 12-06-2014, 04:07 PM
Time's Avatar
.500 RPM...1/2 RPM...I don't think the tach's going to read quite that accurately!
Just kidding with ya + or - 50 rpm is good.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #6 of 7 (permalink) Old 12-06-2014, 04:56 PM
yup sorry fat fingers
post #7 of 7 (permalink) Old 12-07-2014, 02:26 PM
I agree w/ the "check your idle speed" crew.
