versys 650 steering damper - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 03-13-2014, 08:48 AM Thread Starter
I'm new to the forum. Hello everyone.
Need to know available steering damper c/w bracket for versys 650
edabacan is offline
post #2 of 10 (permalink) Old 03-13-2014, 09:08 AM
Probably won't find many because it doesn't need one.
waltermitty is offline
post #3 of 10 (permalink) Old 03-13-2014, 09:24 AM
El Tig's Avatar
+1 She doesn't need one. Someone asked about that a couple of years back but I think even acknowledge it was looks versus function.
BTW,
El Tig is offline
post #4 of 10 (permalink) Old 03-13-2014, 09:31 AM
Agree it doesn't need one. Are you planning on racing it? Racing orgs require them, otherwise I can't think of any other reason, unless you're going to be riding super aggressively?
Hyperpro makes one: http://www.uniquemotorsports.com.sg/...hk=1&Itemid=43
HondaGalToo is offline
post #5 of 10 (permalink) Old 03-13-2014, 09:36 AM
Discussed on this thread:
http://www.kawasakiversys.com/forums...ad.php?t=32497
See post #7 from weljo2001 for a link to one.
More here:
http://www.kawasakiversys.com/forums...ad.php?t=20904
http://www.kawasakiversys.com/forums...ead.php?t=6801
post #6 of 10 (permalink) Old 03-13-2014, 10:15 AM
There is actually this huge fork mounted bracket that attaches to the forks under the headlight and then a dampener plugs into it. I saw one a while back. It's expensive. Then I found out my front end wobble was simply the factory D221 front tire. Once I switched the tires to Shinko 009's I've never had a wobble again.
This was the one I saw: http://www.dmv.com.tw/html/front/bin...ategory=352323 But it's like $140 and that doesn't include the dampener itself.
ZX6RTraded is offline
post #7 of 10 (permalink) Old 03-20-2014, 12:34 PM
El Tig's Avatar
Maybe edabacan really did need a steering damper!
El Tig is offline
post #8 of 10 (permalink) Old 03-20-2014, 04:51 PM
The steering geometry on the Versys is fairly relaxed making it self correcting, such that a steering damper is unnecessary. I've ridden 50,000 km without a single steering oscillation.
If you are experiencing oscillation then it is due to a mechanical issue like head bearings or suspension arm bearings.
post #9 of 10 (permalink) Old 03-20-2014, 10:31 PM
There is one made in Taiwan and I did post it here some years ago but i dont think the V needs one. Just take care of your front end components and you are fine. Brake disc, tire, head bearings ........
post #10 of 10 (permalink) Old 03-25-2014, 11:30 PM
What kind of damper did you want to get?
edsdrag is offline
